Author: Subject: Any PERL experts in the house
mark chandler
posted on 27/11/10 at 09:02 PM Reply With Quote
Years since I did PERL, and I want to extract some text from a Cisco routers config:
I am trying to extract the numbers after Speed (kbps):
MAS_ALDERSHOT_2811_001P#sh DSL int | include Speed
Speed (kbps): 0 11771 0 939
MAS_ALDERSHOT_2811_001P#qCC
Here's my code which I would expect to return the whole line
sub Parse_DLSWspeeds{
my @line=@_;
my ($ADSLspeed) = ($line[0] =~ /Speed (.*)/m) or die;
return $ADSLspeed;
but it just returns:
(kbps)
Anyone any idea what I need to pull in the whole line? it stops when it arrives at the ':' after (kbps)
Cheers Mark
[Edited on 27/11/10 by mark chandler]
BenTyreman
posted on 27/11/10 at 09:47 PM Reply With Quote
A quick bit of Googleing suggests your regex should be
code:
m/Speed (.*)/
not
code:
/Speed (.*)/m
Don't know about the rest of the code, but it might be a start. Personally, I would have thought something like
code:
if ($line[0] =~ m/Speed (.*)/) {
return $1
} else {
return ""
is simpler.
[Edited on 27/11/10 by BenTyreman]
Mark Allanson
posted on 27/11/10 at 09:49 PM Reply With Quote
Wow - I understood all of that - not
mark chandler
posted on 27/11/10 at 10:27 PM Reply With Quote
Thanks Ben
Unfortunately the same result, its is still stopping at :
I cannot see why this is not being captured with .*
BenTyreman
posted on 27/11/10 at 10:58 PM Reply With Quote
I have just tested this code
code:
#!/usr/bin/env perl
sub parse_speed {
if (shift =~ m/Speed (.*)/) {
return $1;
} else {
return "not found";
print(parse_speed('Speed (kbps): 0 11771 0 939'));
and it returns
code:
Calling
code:
print(parse_speed('Spezzzed (kbps): 0 11771 0 939'));
returns
code:
not found
If this doesn't work on your system, then I have exhausted my knowledge of Perl.
mark chandler
posted on 27/11/10 at 11:11 PM Reply With Quote
Wow thanks for trying Ben, unfortunately no banana, I think that the Cisco router must be returning the line in an odd format....
return $1;
} else {
return "not found";
Still returns (kbps) When its sucked from the router, it works correctly when sourced from a text file.
If I match with ^\s (which should ignore blank characters) then it returns not found which confirms this I think.
Boo
Regards Mark
scudderfish
posted on 28/11/10 at 10:36 AM Reply With Quote
Or how about a bit of sh
cat tst.txt | grep "Speed (kbps):" | cut -f 2-5
mark chandler
posted on 28/11/10 at 08:41 PM Reply With Quote
Thanks chaps
Got there in the end, reloaded perl.... and it started to behave as I expected. bugger 2 days wasted!
ChrisW
posted on 28/11/10 at 11:15 PM Reply With Quote
If it was just the numbers you wanted, I'd have preffered:
if ($line =~ /Speed.*([0-9 ]+)/) {
$speed = $1;
Chris
