bigbravedave
| posted on 28/11/10 at 08:48 PM |
how do you get rid of the watermark.exe virus
how do you get rid of the watermark.exe virus?
ive tried mcafee and anti malware and still no joy, any ideas,
many thanks
RichardK
| posted on 28/11/10 at 08:53 PM |
I've always found the eset online scanner to be helpful
http://www.eset.com/online-scanner
Rich
Gallery updated 11/01/2011
T66
| posted on 28/11/10 at 08:56 PM |
www.bleepingcomputer.com
search for it and follow the instructions, someone will have had it before you..
or try majorgeeks.com
jossey
| posted on 28/11/10 at 09:29 PM |
Try this
http://comprolive.com/remove/worm/ramnit/watermark-exe
Make sure you have good AV on your pc. You pc will last about 60 seconds on net before you pickup a virus or spyware etc.
Dave
Mr G
| posted on 28/11/10 at 10:55 PM |
What os are you running? First call for me is to roll the system back to an earlier date pre-infection
T66
| posted on 29/11/10 at 06:46 AM |
The thing is with that, is the virus remains where it is...
PC needs booting up in safe mode to remove the virus, as far as I understand the PC will backup everything with system restore, which to get rid of
the virus needs to be disabled.
bleepingcomputer.com will hold the answer, has bailed me out more than once.
I am not a PC expert, and have successfully removed umpteen virus after over enthusiastic surfing by my teenage sons.
mad4x4
| posted on 29/11/10 at 07:38 AM |
No............ don't Do it /....................
(never seen it work only screws up your machine more IMHO)
Scot's do it better in Kilts.
| posted on 29/11/10 at 10:03 AM |
First step is to disable system restore then get rid of the .exe then go through registry and internet temp files and delete all references to it.
Mr G
| posted on 29/11/10 at 06:12 PM |
Edit : Horses for courses. Never had any trouble on numerous machines. O bviously need to do it properly and use other software etc
I've been lucky then
Roll back so the virus can't boot
Remove virus with avast/MSE/Anti-malware
Disable system points/ delete post virus points.
etc etc
[Edited on 29/11/10 by Mr G]
