Steve Hignett
| posted on 10/12/10 at 08:27 AM |
Help wanted:- Can anyone convert an image into a .DST file pls?
Hi All,
As above guys, I have 3 or 4 images that I need converting to a .DST file, can anyone help out please?
Thanks in advance once again,
mcerd1
| posted on 10/12/10 at 08:37 AM |
is that an Embroidery file ? (had to google that - dst is a file for autocad, but its a settings file....) - I can't do these
or do you mean a DSTV file (normally *.nc1) these are CNC files - I can do these for plates and most steel sections
Steve Hignett
| posted on 10/12/10 at 05:47 PM |
Err, the embroidery one you can't do
Damn it...
Anyone else?
plentywahalla
| posted on 10/12/10 at 11:30 PM |
I can programme .dst files for embroidery machines, and embroider them also if you want.
I have software that in theory can convert bitmaps to .dst at the click of a button, but in practise what they generate is pretty well useless. In
practise you need to generate the file from scratch using the bitmap as a template which is quite a lengthy process. You also need to run the
programme on an embroidery machine to fine tune it for the particular material you are embroidering as each material reacts differently.
Hope this helps ... need to know eaxactly what you want ... and why.
Steve Hignett
| posted on 11/12/10 at 05:44 PM |
U2U sent...
McLannahan
| posted on 13/12/10 at 11:47 AM |
Pants - U2 sent too.
