r1_pete
| posted on 13/12/10 at 06:49 PM |
USB - Serial adapter for Magajolt advice needed
My last T23 laptop has just packed up, so I dont have a laptop with a serial port any longer.
Does anyone have experience of using a USB-Serial adapter with MJLJ?
A brand, supplier, whether it uses the FTDI or prolific chipset etc. would be useful.
Any help gratfully received.
[Edited on 13/12/10 by r1_pete]
big_wasa
| posted on 13/12/10 at 06:51 PM |
ive got an unbranded one with the prolific chipset and it works fine.
blakep82
| posted on 13/12/10 at 06:52 PM |
i got a cheap one from misco.co.uk, don't know the exact one, but mine worked
________________________
snapper
| posted on 13/12/10 at 07:04 PM |
The most frequent problem is the adaptor populating a different com port every time, the com ports are then populated above com port 10, megajolt tune
can only see com port 1 to 10 zo you have to go in to device manager and delete devices on the required com port.
The V4 jolt uses Ethernet cable and does not suffer the com port problem
I eat to survive
I drink to forget
paulf
| posted on 14/12/10 at 12:14 AM |
It still connects to a serial port ,its just that the connector is an Ethernet plug at the megajolt end.I found the USB leads sold by Maplins work
ok.
Paul
