Wadders
posted on 21/7/04 at 09:06 PM |
emails
Is there any way to retrieve sent, unread emails? Iv'e stupidly sent a quote out, forgetting to add the vat on. and i'd rather not send
another email pointing out the fact.
ta Al.
Staple balls
posted on 21/7/04 at 09:52 PM |
nope, unfortunately not possible i'm afraid
Wadders
posted on 21/7/04 at 10:01 PM |
bugger, guess i'll just have to give em the bad news.
Ta for the answer tho'
i]Originally posted by Staple balls
Donners90
posted on 21/7/04 at 10:17 PM |
Outlook
If you are using outlook, isn't it possible to recall a message or does that only work on a LAN or when the person you sent it to is on the same
server?
Anyway, if it works through POP3 then you could try going to your sent mail folder. Open the message you sent then go to 'Actions' in the
menu bar then select recall?
HTH
James
[Edited on 21-7-2004 by Donners90]
ned
posted on 22/7/04 at 08:53 AM |
as far as i know the outlook recall function only works on a lan with an exchange server...
Ned.
beware, I've got yellow skin
