morcus
posted on 20/9/11 at 07:17 PM |
Do Road car aero kits do anything?
As per title, does anyone actually gain anything on the road from spoilers and splitters and that kind of thing? I understand how it works but would
you feel any benefit at 60mph?
Ivan
posted on 20/9/11 at 08:08 PM |
Unless it's been designed in a wind tunnel by someone who knows what they are doing i doubt that you would gain anything at any speed except
increase resistance.
MikeR
posted on 20/9/11 at 08:35 PM |
you'll get at least 100hp and half your 0-60 bragging time!
scutter
posted on 21/9/11 at 10:00 AM |
By panelling off the rear of my car we gained 10mph, no aero increase but a reduction in drag.
ATB Dan.
jossey
posted on 21/9/11 at 11:48 AM |
scutter what do you mean by that please? Boxed of the Bottom and top or what......
David Johnson
MikeR
posted on 21/9/11 at 12:10 PM |
probably the rear boot area and maybe trans tunnel. Issue is making sure the heat from the engine, box and diff can escape.
Kwik
posted on 21/9/11 at 12:49 PM |
you dont need an air tunnel to get gains in drag efficiency. you just have to get your car as close to a teardrop shape as possible, less hard edges,
no gaping holes, cover as much as you can off the wheels...
to get performance gains in down force you dont need a wind tunnel, but if you bolt the wrong bits onto the wrong car then it wont be beneficial at
all... the wind tunnel will just make a particular aero part more efficient...
scutter
posted on 21/9/11 at 01:08 PM |
I made a cheap undertray/diffuser from the rear edge of the floor to under the fuel tank, The thinking was it'll stop the rear panel acting like
a parachute.
ATB Dan.
[Edited on 21/9/11 by scutter]
coyoteboy
posted on 22/9/11 at 02:38 PM |
Teardrop isn't actually the most aerodynamic shape, it's partly that shape due to the effects of surface tension and gravity. If it were
you'd see fighter aircraft with bulbous noses and pointy tails - you don't they're pointy at both ends, as close as can be around
the payload.
My cars rear wing (OEM) makes a big difference to stability near 80mph, really pins the back end down (makes sense, it's an inverted aerofoil in
shape) - removing it is noticable. But most "ironing board" solutinos I'd say no, and most bolt on extras I'd say need some
thought. Complete Undertrays are probably about yoru best bet.
[Edited on 22/9/11 by coyoteboy]
Mr Whippy
posted on 22/9/11 at 03:50 PM |
a teardrop shape is really a bad idea, rather like the old vw beetle the try to fly at the back and become unstable
All spoilers really do is add drag to the car, in an ideal world the spoiler fin would move and only produce downforce when needed, i.e. going round
corners, in the straight it's just a drag
RK
posted on 23/9/11 at 01:43 AM |
You might not feel any benefit at 60 mph, but you certainly would at rest. Your knob grows exponentially. Perhaps not all that useful at that moment
in time...
Rob Palin
posted on 23/9/11 at 05:27 AM |
the payload.
The teardrop is exactly the perfect shape for low drag - gravity and surface tension work in opposition until the lowest energy combination is
reached, which is a teardrop.
Modern fighter aircraft are pointy at both ends because they need to have the capability to go supersonic in order to get to 'the fight'
quickly. When near or over the speed of sound the most efficient shape has a pointy front. When substantially below the speed of sound, a rounded
front is the most efficient shape.
It's why propeller-engined fighters always used to be rounded but the more recent jets became pointy. Unfortunately the pointiness makes the
handling poor when at low speed so they tend to have deployable slats and flaps at the front and rear of the wing, to try and increase the overall
curvature and make it more like a low speed wing.
I've been developing cars and aero kits professionally for 15 years now and have seen that there's a wide variety of stuff out there with
some that does work well and plenty that doesn't. In truth it's difficult to make a spoiler that doesn't do *something*, but
whether it does so efficiently or to anywhere near the full potential is the big question.
In some cases they can increase drag, in some they lower it. It depends entirely on the shape of the car and the design of the spoiler. You
definitely want one designed by someone who knows what they're doing and had it tested, and tested properly.
posted on 23/9/11 at 07:15 AM |
Elongated half tear drop
[Edited on 23/9/11 by britishtrident]
posted on 23/9/11 at 11:32 AM |
quote: Originally posted by Mr Whippy
... in an ideal world the spoiler fin would move and only produce downforce when needed, i.e. going round corners, in the straight it's just a
drag
Did the original TT test-car not do cartwheels in a straight line at high speeds when it had no wing?
It's Evolution Baby!
Ninehigh
posted on 23/9/11 at 03:20 PM |
A water droplet is actually a ball, not "tear" shaped....
There probably is a difference at 60mph+, but really unless you're on a track (or thrashing it like you're on GTA) I wouldn't bet on
you feeling a difference
