Author: Subject: unable to download.
tigertom
posted on 17/8/04 at 08:20 PM Reply With Quote
unable to download.
just got this computer and borrowed a digital camera from work to download pictures of my car to use as an avatar and i cant get the feckin' thing to work.its a fuji camera and the usb cable is plugged in to back of harddrive.any help would be appreciated before this feckin' camera goes back in bits.
mangogrooveworkshop
posted on 17/8/04 at 08:22 PM Reply With Quote
have you got a disc that comes with the camera
tigertom
posted on 17/8/04 at 08:28 PM Reply With Quote
if its a disc that goes into the computer then no.
mookaloid
posted on 17/8/04 at 08:32 PM Reply With Quote
I just plug my camera into the computer with the USB cable and it appears as another drive in My Computer
liam.mccaffrey
posted on 17/8/04 at 09:05 PM Reply With Quote
thats only with xp and maybe 2000 (not sure bout 2000)
if its another (windows) os you'll need drivers methinks
try manufacturers website fuji
Build Blog
Build Photo Album
posted on 17/8/04 at 09:45 PM Reply With Quote
Sounds like you need the USB Drivers for your camera...
but there's no point loosing patience with something that you knew little about in the first place
Things aren't normally THAT easy are they?
stephen_gusterson
posted on 17/8/04 at 10:20 PM Reply With Quote
go and buy a car reader......
unless you have a crappy cheapo camera, the memory card will come out. you plug this into a reader unit, which typically also is usb.
diference is, something you buy will have the drivers! the bigger tescos have readrs for a tenner and you can get similar on ebay
atb
steve
liam.mccaffrey
posted on 17/8/04 at 11:03 PM Reply With Quote
should've said before what steve gusto said
"buy a card reader" then you will never use that crappy camera cable ever again
i am a big advocate of the memory card it is just so much better than anything else, quick small reliable and fairly cheap
my new work computer doesn't have a floppy drive just a slot for a memory card
Build Blog
Build Photo Album
Benzine
posted on 18/8/04 at 08:33 AM Reply With Quote
Maybe its not working because of the new orifice you have created in the harddrive
The mental gymnastics a landlord will employ to justify immoral actions is clinically fascinating. Just because something is legal doesn't make it moral.
