Jamster1233
posted on 12/2/12 at 05:51 PM |
locost side panels
is it worth getting the fiberglass side panels or stick with the alluminium ones ?
designer
posted on 12/2/12 at 07:20 PM |
The choice is yours!
Hugh_
posted on 12/2/12 at 07:58 PM |
I considered this, in the end stuck with ali because I reckoned that as it was easiest to attach the exhaust silencer to the side panel, ali could be
reinforced and at worst would bend a bit, but fibreglass could crack-up and be alot harder to repair. As it happens with the reinforcement to the ali
the silencer has hung from it fine with no movement!
b14wrc
posted on 22/2/12 at 12:18 PM |
I plan to make mine from Carbon Fibre.
20vt powered rear engined locost
