Author: Subject: Why does it slide sideways?
Ivan
posted on 1/3/12 at 07:15 AM Reply With Quote
Scenario: Standing on a straight relatively smooth road without much camber, all wheels pointing straight, floor accelerator, car flicks sideways, correct, get some traction but wheels still spinning somewhat and car starts snaking down the road.
Question: Why the sideways action and then snaking down the road.
Suspicion: Some bending and twisting in the rear suspension arms but why the serious flick sideways on takeoff?
[Edited on 1/3/12 by Ivan]
snapper
posted on 1/3/12 at 07:23 AM Reply With Quote
Torque effect from the engine spinning in one direction
Without a limited slip diff one wheel will slip first leaving the other with all the grip until that spins, when the other will now have more grip.
[Edited on 1/3/12 by snapper]
I eat to survive
I drink to forget
loggyboy
posted on 1/3/12 at 08:24 AM Reply With Quote
several reasons. The road will never be dead flat, the grip will never be perfectly even, power will never be exactly equal, steering will never be dead straight.
All these factors along with the mass of the car not wanting to move, means the forces the spining wheels create translate down the easiest route, which is sideways as the force only has to move (approx) 50% of the weight of the car
[Edited on 1/3/12 by loggyboy]
omega0684
posted on 1/3/12 at 08:47 AM Reply With Quote
don't worry about the math, just enjoy it, remember you look cool doing burnouts in a kit!
MakeEverything
posted on 1/3/12 at 08:50 AM Reply With Quote
U til something goes bang, you hit something or get nicked!
Kindest Regards,
Richard.
omega0684
posted on 1/3/12 at 08:51 AM Reply With Quote
Fix it, drive more responsibly, buy big padlocks.
[Edited on 1/3/12 by omega0684]
loggyboy
posted on 1/3/12 at 09:12 AM Reply With Quote
If only it was that simple to avoid posecution, Id have the biggest padlocks and the cleanest licence!
Dusty
posted on 1/3/12 at 09:13 AM Reply With Quote
If you do a burnout in a trike style car with one wheel at the back putting the power down, two up reasonably matched for weight and on a flat airfield runway does it still slide sideways?
dhutch
posted on 1/3/12 at 09:24 AM Reply With Quote
Because there is nothing stoping it.
Put a airhockey puck on a air hockey table, and it will move off, in one direction or the other. Nothing is ever perfectly flat, balanced, loaded, symetrical, and untill then it will move.
Daniel
Andi
posted on 1/3/12 at 10:32 AM Reply With Quote
If it goes quickly and uncontrollably sideways every time then surely something is amiss?
Its never happened to me, not noticed too many drag racing burnouts spinning to one side either
Andi
Daddylonglegs
posted on 1/3/12 at 10:42 AM Reply With Quote
I don't think I'll ever have to worry about snakeing in my jallopy, after all, I'm running a 1980's Cortina Anchor
[Edited on 1/3/12 by Daddylonglegs]
A1
posted on 1/3/12 at 12:22 PM Reply With Quote
you might have a big thrust angle. mine used to always slide to the left in similar circumstances, got the thrust angle sorted and now it goes straight.
Dusty
posted on 1/3/12 at 12:42 PM Reply With Quote
Because there is nothing stopping it.
I would have thought the approach of 'What's making it' would be more profitable. One poster comments thrust angle. Others torque reaction. Weight transfer across the back axle, etc Position of driving wheels well off centre line must exaggerate the tendency to snake. I would have thought something like a scorpion would have only a very small tendency to snake on a flat road. Any trike owners care to comment?
[Edited on 1/3/12 by Dusty]
posted on 1/3/12 at 01:08 PM Reply With Quote
With a live axle it will.
loggyboy
posted on 1/3/12 at 01:32 PM Reply With Quote
A live axle reverse trike - thats an interesting concept!
maccmike
posted on 1/3/12 at 02:02 PM Reply With Quote
dhutch, mine does
Hugh_
posted on 1/3/12 at 02:07 PM Reply With Quote
Originally posted by Andinot noticed too many drag racing burnouts spinning to one side either
not too many drag racers out there without an LSD...
Ivan
posted on 1/3/12 at 03:03 PM Reply With Quote
Andi
Nope not quickly or uncontrollably - but enough to need correction and only when there's significant wheelspin.
Chippy
posted on 1/3/12 at 04:05 PM Reply With Quote
When you plant the throttle, and as long as you don't run a Honda anti clock engine, the car will always, (if you have enough torque), slip left initially due to the engine attempting to lift the left side of the car, even slightly. This effect is less noticable on a heavy old barge, (most tin tops). This is what I was informed some years ago by a guy who knows a great deal more about performance cars than I did, (and still do), :-). Cheers Ray
