Author: Subject: Pinto Plumbing
mkeats02
posted on 2/3/12 at 12:58 PM Reply With Quote
Pinto Plumbing
Hi There
I am after some help with regard to pinto plumbing.
I have a header tank that has three in/outlets and a pressurised cap.
what I have worked out so far is
1 - the bottom feed from the header to a connect to a T-piece to the lower rad to waterpump hose
2 - Upper Rad to Thermostat
3 - By-pass system, Small water pump hose to inlet manifold.
This leaves me with two connections on the header tank, which of the following do I go with?
4 - Small thermo, currently blanked off, use this to go to the top of the header along with the rad overflow using a T-piece, blanking off the middle middle inlet/outlet on the header?
or
4 - can I the small stat take-off (currently blanked) and return to the upper header tank in/outlet with the rad overflow going to the middle inlet/outlet on the header tank.
Thanks, much appreciated
Mike
RichardK
posted on 2/3/12 at 01:17 PM Reply With Quote
I used to have a pinto so the older pictures in my gallery my help.
Rich
Gallery updated 11/01/2011
Hugh_
posted on 2/3/12 at 02:30 PM Reply With Quote
My header tank has an outlet and an overflow.
1 - as yours
2 - as yours
3 - as yours
I have small thermostat to header tank overflow.
I have the rad overflow blocked with a screw so that I can still use it to bleed when refilling the system.
