Fizzer
posted on 21/3/12 at 10:48 AM |
re-use blacktop head studs
Thinking of getting my ports polished (ooer). Should I replace my head studs? (not minted, so would rather not...)
It's a focus blacktop.
TIA
loggyboy
posted on 21/3/12 at 11:30 AM |
When ive done heads before, the general rule is stretch bolts should be replaced. however on my clio 172 there was note in the renault guide that if
theyve not stretched past a certain length they can be reused, but I didnt have an accurate way of measuring (10ths or 100ths of mm or so) so I just
replaced them, in my experience they arent expensive, no more a £1 or 2 each.
Greenie
posted on 21/3/12 at 11:48 AM |
What does the polishing process consist of and is it expensive?
Fizzer
posted on 21/3/12 at 12:00 PM |
I'm thinking of sending it this chap:
http://www.aldevelopments.com/index.php
Just seen standard bolt prices for heads on ebay, they are mega cheap so will fit new ones. Interestingly, some people are selling bolts and some
people are selling studs for the same engine... wierd. Anyone know what the standard fitment actually is? Bolts or studs?
Paul Turner
posted on 21/3/12 at 12:53 PM |
Don't use bolts etc from e-bay, they are sometimes not up to OEM standards and can cause problems with headgaskets and warped heads down the
line. I bought mine form a local factor some years ago but never again, they were OK but genuine Ford ones were cheaper.
Standard fitment is bolt.
[Edited on 21/3/12 by Paul Turner]
JAG
posted on 21/3/12 at 01:09 PM |
Standard fitment is bolts - at least that's what was on my Focus 1.6 Zetec SE (Black cam cover)
Justin
Andrew@ALD
posted on 21/3/12 at 10:09 PM |
For more info on head work and whats involved then please read here
http://www.aldevelopments.com/Head-Work-Guide.php
Fizzer
posted on 6/4/12 at 04:32 PM |
Will these fit? I have a 2.0 blacktop.
http://www.burtonpower.com/fz190.html
I always get confused by each online stores' description. Why not say blacktop or silvertop?! ![](/images//smilies/smile.gif)
Andrew@ALD
posted on 7/4/12 at 03:45 PM |
When i comes to Zetec they normally say pre or post 97
All Zetec's share the same head bolts
Andrew@aldevelopments.com
