Ian Jones
posted on 20/4/13 at 07:05 PM |
how thick for foam bonnet tape
as above really, how this do people use?
I have seen some that is 20mm wide and 1.5mm//3mm//4.5mm//6mm thick
it is to be used on the car between the bonnet
whats the best thickness to use?
thanks
ian
MsD
posted on 20/4/13 at 07:28 PM |
I'm in the same boat.. So id like to see the answer
I've got some but its pretty thick and will show up like a sore thumb on a white car!
Mark.
posted on 20/4/13 at 07:38 PM |
Depends on how much of a gap you have between the scuttle and bonnet etc
twybrow
posted on 20/4/13 at 07:56 PM |
I bought the tape that was about 3mm thick. Where I needed it thicker I just taped it to itself - works a treat!
ReMan
posted on 20/4/13 at 08:00 PM |
I only used 3mm on the bonnet where it contacts the scuttle and nosecone
Used helicopter tape on the sides to stop the bonnet and side abrading together.
that way no foam to be seen
www.plusnine.co.uk
snapper
posted on 21/4/13 at 07:04 AM |
I used push bike inner tube for nose and scuttle ends, 3 mm foam for engine bay sides
Inner tube looks like new and cleans with a wipe
Foam looks old and pitted, soaks up oil and muck, if I replace it ill use rubber dots
I eat to survive
I drink to forget
40inches
posted on 21/4/13 at 09:19 AM |
I used Tadpole trim between bonnet and nose cone, 5mm foam along bonnet and chassis, and bonnet to scuttle.
5mm will squash down to 2-3mm easily, and fills gap between bonnet and chassis top.
![](/galpreviews/Nose Cone Vent.JPG) ![Description](/gallery/Nose Cone Vent.JPG) Description
![](/galpreviews/20120812_122917 Large.jpg) ![Description](/gallery/20120812_122917 Large.jpg) Description
