Sloan85
posted on 29/4/13 at 09:55 PM |
Handbrake cable resting on rear uprights. Is this right?
Just wondering where the rear handbrake cables should sit in relation to the rear uprights. Currently the cable is positioned as can be seen in the
picture below. Is this right? It's very close to the wheel at the minute and will probably wear the powdercoating away on the top of the
upright.
http://mkindygsxr.blogspot.co.uk
loggyboy
posted on 29/4/13 at 09:59 PM |
Slide a bit of rubber tubing over it, that's what manufacturers do.
Mistral Motorsport
bi22le
posted on 29/4/13 at 10:02 PM |
Completly different car, I know, but mine are horizontal and go under the lower wishbone.
Have you got it on the right side?
Please read my ring story:
Mark Allanson
posted on 29/4/13 at 10:36 PM |
Mr IVA won't like that
Madinventions
posted on 29/4/13 at 10:45 PM |
Again, completely different car but these are my Sierra calipers on the nearside rear, viewed from underneath. Putting them on this way brings the
cable out horizontally along the bottom of the wishbone and puts the bleed nipple at the top.
View my band website:
http://www.shadowlight.org.uk
PeteMKfazer1000
posted on 9/6/13 at 07:23 PM |
How did you solve this problem?
Sloan85
posted on 13/6/13 at 05:11 AM |
I haven't yet! Any other suggestions??
Ben_Copeland
posted on 13/6/13 at 05:58 AM |
Just make up a little bracket to hold the handbrake cable, bolt it to the upright using that top wishbone mount. Bit of rubber around cable and
it'll look like its supposed to be there.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
doobrychat
posted on 13/6/13 at 07:07 PM |
my iva bloke picked up on my handbrake cable rubbing.. i got some cable ties and small rubber tube and looped the cable through it with the hose to
my wishbones for my retest and he said that its looks good and secure..
so he passed it...
RSr
posted on 21/8/13 at 08:49 PM |
Here's how it looks on mine.
The cable is from a Sierra.
//Rickard
Sloan85
posted on 21/8/13 at 10:19 PM |
Thanks for the reply. I did manage get this sorted in the end. I bent the cables to the side and fixed them to the diagonal bracing at the top of the
shock absorber with rubber lines p clips. Once clipped it can't slide and so will never rub against the wheel.
Photos in my build diary.
Build diary - Fixing handbrake cables
