Author: Subject: TV Capture Device
Mark Allanson
posted on 9/6/13 at 05:52 PM Reply With Quote
TV Capture Device
Mt Mrs watches some rubbish on TV, Emmerdate, Corry, East Enders, My Britains got a voice, etc so I tend to spend most of my evenings either in the garage or on the computer.
There are some programs I would like to watch so I have a TV USB dongle, a Hauppage Win TV DVB-T Nova-T. Unfortunately I have mislaid the serial key and for some reason it is now demanding it! The software for it is very poor, if a signal for a channel is low, the whole thing freezes and has to be shut down and restart to continue, the channel acquisition is random, and channel are allocated the channel numbers apparently by lottery!
So, I need a new one, I don't mind if it is a stick or a PCI card, but need recommendations, or which ones to avoid, or any other solutions I haven't thought of
Over to you, the fountain of all knowledge
Slimy38
posted on 9/6/13 at 06:34 PM Reply With Quote
Have you considered internet TV? Most big channels now have some sort of 'catch up' option, and while it might not all be live, there is a lot of content out there. I've found it needs at least 1 Meg internet though to stay smooth.
I can't help on the dongle side I'm afraid. I've had a few digital TV dongles, and not yet found a good one. I think it's mostly the aerial they plug into, even the more expensive units with external aerials are still only relying on a six inch piece of wire.
whitestu
posted on 9/6/13 at 06:49 PM Reply With Quote
As above, if you have broadband use something like TV catch up.
Stu
chrism
posted on 9/6/13 at 06:51 PM Reply With Quote
http://www.tvcatchup.com/
lets you watch live tv Free to use. Obviously requires internet.
If no internet, I think you may be able to download other tv viewing programs to use with your dongle, it may just be the bundled software that requires the serial.
A little hard work never killed anyone, but why take the risk!
posted on 9/6/13 at 07:27 PM Reply With Quote
Just make sure that you've got a generous download allowance from your ISP before using TVcatchup or BBC's iPlayer...
posted on 9/6/13 at 09:21 PM Reply With Quote
Do you have the CD that came with the dongle ? You can download the software for it on the Hauppauge site here.
Mark Allanson
posted on 9/6/13 at 09:56 PM Reply With Quote
Pete,
I have the CD but not the serial key and the crafty buggers want 39.95 dollars for a new one, even though I have the hardware which cannot be copied
Scuzzle
posted on 10/6/13 at 08:05 AM Reply With Quote
I'm using the Avermedia TVVolar USB stick on my PC and it's fine, I just us it to watch TV on my laptop through Windows Media Centre. Picks up over 100 digital freeview channels with no problems and no activation key. It does come with it's own software but I just prefer Media Centre.
It will play up if you have a weak signal, I live in a weak signal area so I need a plug in booster and on wet windy days I can sometimes lose a few channels but on a decent day I get everything fine, that's more my freeview aerial setup's fault than the USB TV card though.
AVERMEDIA DVB-T PC HD TV A835 BLACK | eBay
Edit - I should mention this just takes the standard RF aerial socket which is a plus, some have micro plug adapter lead which is really easily broken and you can't replace them when they break either.
[Edited on 10/6/13 by Scuzzle]
Mark Allanson
posted on 10/6/13 at 08:20 AM Reply With Quote
I may have a go at that, I noticed that you use media centre (windows?) - I tried that with the WinTV stick but could't figure out how to make one work with the other
TimEllershaw
posted on 10/6/13 at 10:48 AM Reply With Quote
I used to use a couple of bits of software with my Hauppage card : ProgDVB (free) and DVB viewer (15 euros). I've not used them in ages, so they may have been overtaken by other things like MediaPortal now. They should work with your dongle.
I may even have a copy of the Hauppage software somewhere, so I'll have a look for the disc / serial number tonight if that helps.
Tim.
[Edited on 10/6/2013 by TimEllershaw]
http://www.teenagecancertrust.org/
swanny
posted on 10/6/13 at 01:11 PM Reply With Quote
sorry for the hijack (ish) post, but would one of these things mean you could watch tv in europe? was just wondering about getting TV at le mans if one of the local free view channels showed any?
paul
TimEllershaw
posted on 10/6/13 at 01:24 PM Reply With Quote
paul
Good idea !
Yes, should work. France uses the same DVB-T technology.
I've even heard of people picking up French channels in Kent in the right weather and with a decent aerial.
Mark Allanson
posted on 10/6/13 at 03:33 PM Reply With Quote
Tim.
Thats ideal - thanks
TimEllershaw
posted on 10/6/13 at 07:35 PM Reply With Quote
I have had a look and I have the install cd for Hauppauge WinTV-2000 v1.3 for Nova-T, but can't find anything with a serial number on. You are welcome to it, but to be honest it is older than I realised, so you would be better off with one of the many shareware DVB applications.
Tim.
Mark Allanson
posted on 10/6/13 at 08:32 PM Reply With Quote
Tim.
Tim,
Thanks for the offer, I have the install disc but won't let me complete the install without the serial key, I will try these third party DVB apps
Mark
