Mark Allanson
posted on 8/7/13 at 09:08 PM |
OS Upgrade
Every couple of years I upgrade my computer with bits donated by my cutting edge kids.
I now have a motherboard with 8 gig of memory, a triple core processor, a blank 1tb HD, but no OS, I am just about to order Windows 7 home premium
64bit SP1 from ebuyer, before I press the button, does anyone recommend I go for 8, or a different version of 7.
Advice eagerly awaited
(no votes for Linux as I don't have clue how it works or how to get drivers for all my PCI bits and bobs)
chrism
posted on 8/7/13 at 09:15 PM |
Best to stick with 7, definately dont want 8 unless youve got a touch enabled display.
A little hard work never killed anyone, but why take the risk!
SteveWalker
posted on 8/7/13 at 09:27 PM |
Personally I'd go for 8 (I have done on both our PCs), but then install the free download "Classic Shell" which lets you boot
straight to the desktop, re-instates the Start Button, IE's menu bars, etc. and will let you select the look and feel of 7, XP or Windows
Classic. That way you get the latest OS (8 is a little more efficient than 7), but the familiarity of whichever version of Windows you prefer.
Brett Jones
posted on 8/7/13 at 09:28 PM |
If you go with 8 you might find that it doesn't have the correct drivers to set everything up on your older motherboard, so it would be best to
stick with 7.
http://mnrvtecvortxbuild.blogspot.co.uk/
Mark Allanson
posted on 8/7/13 at 09:32 PM |
I have also decided to go for a SSD 60GB drive for which ever OS I go for, anyone else go for 8 with classic shell?
posted on 8/7/13 at 09:47 PM |
I've got Windows 8 64 bit with Stardock 8 which is commercial solution to fix
the ridiculous "Modern" interface, it's only 5 US Dollars. Without it I doubt my PC would have survived until now as I'd
probably have stamped on it in a rage With the proper start menu, Windows 8 seems fine. It's very fast with an SSD due to the hybrid sleep
mode, mine boots in under 5 seconds.
So far I have found no significant issues or incompatibilities, the worst for me being the Cisco VPN client I use when working at home that stops
Windows shutting down after using it, but this is due to be fixed (by Cisco).
[Edited on 8/7/13 by MikeRJ]
SteveWalker
posted on 8/7/13 at 10:04 PM |
stick with 7.
I've had no driver problems, despite relatively old kit, but general opinion seems to be that windows 7 or Vista drivers will work with 8
anyway.
stevebubs
posted on 8/7/13 at 10:08 PM |
Go with 8....
posted on 8/7/13 at 10:32 PM |
The point about Linux is it comes with a complete set of drivers, just stick in a bootable DVD or CD in answer a few simple question and the
hardware detecion sorts it all out, the computer is up and running in 20 minutes complete with office software.
twybrow
posted on 8/7/13 at 11:00 PM |
I also use Windows 8 with a start button/classic shell app. I like it. To be fair I also liked it without the Start button, but my IT man at work
didn't! With an SSD, it is bloody quick. I have had a few issues to sort, but nothing tricky.
Not Anumber
posted on 8/7/13 at 11:03 PM |
+1 for Linux. If you are used to the look and feel of Windows XP or Windows 7 then use Linux Mint as you will be able to use it straight away with
no issues or conflicts.
posted on 9/7/13 at 07:12 AM |
Classic shell is good it get rid of the biggest objection to Windows but but some Windows 8 annoyances remain, to b be fair most version of the
Windows interface have niggling differences in thse interfaces to the techie stuff such as Control Panel and Networking.
snakebelly
posted on 9/7/13 at 07:39 AM |
be very careful going with a 60Gb SSD, I did this on the win7 machine at home and it very quickly became full even though I was using it for the OS
only. you can get round it be redirecting some storage to other drives but its a pain. In the end I buckled and splashed for a 250Gb drive.
[Edited on 9/7/13 by snakebelly]
