Lightning
posted on 14/11/13 at 10:48 AM |
help required re expanding grout
As this forum is the font of all knowledge, can one of you steer me in the right direction.
Industrial, massive steel chimney. The client wants an Expanding grout under the base plate to seal a 75mm gap so water cannot get to the holding down
bolts (2.5m diameter)
Can anyone recommend what I want?
Many thanks
designer
posted on 14/11/13 at 01:36 PM |
Expanding grout?
Surely you mean a gap filling foam? It's readily available.
femster87
posted on 14/11/13 at 01:47 PM |
Yeap, there is such a thing. Its called non-shrink grout. I have not used any, but I came across it at work. From a google search. Looks like travis
perkins have some
Lightning
posted on 14/11/13 at 02:22 PM |
That's what I thought use gap filling foam its the client that wants expandable grout. Travis do some but what I can see isn't suitable
for that size gap
theprisioner
posted on 14/11/13 at 05:11 PM |
I have used a product similar to this before:
http://www.quikrete.com/productlines/FastSetNonShrinkGrout.asp
Cementaneous non shrinking grout is what is normally used on this app I think?
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
woodster
posted on 17/11/13 at 08:49 PM |
At work we used a 2 pack epoxy resin grout to fill in the gap around holding down bolts under base plates on steel stanchions, can't for the
life of me remember it's name but it came from Buildbase and it went off like bell metal, the structural engineer specified it .
Sloan85
posted on 17/11/13 at 09:05 PM |
Non-shrink ground is used to transfer load from baseplate to structure underneath. A couple we use on site are Weber 5 star and Conbextra.
[Edited on 17/11/13 by Sloan85]
http://mkindygsxr.blogspot.co.uk
theprisioner
posted on 17/11/13 at 11:35 PM |
"Conbextra" is what I used, I was trying to remember that. Very effective product. Stronger than concrete and waterproof. You need to make
a temporary shutter.
Lightning
posted on 18/11/13 at 10:09 AM |
Thanks Y'all
