davidimurray
posted on 5/12/13 at 10:45 AM |
Network over power
A question for the boffins on here -
I have Broadband in the house with a wireless router in the front downstairs room. I can get a Wifi signal as far as the patio, but nothing beyond
that. My garage is about 30 foot away from the house and about 10 foot below it. Hence there is no way I can get Wifi down there.
I've been looking at the network over power circuit devices but none seem to give any info on distances. If these worked, I could put an adaptor
in the front room, then the garage comes off the fuseboard for the rest of the house so in theory it is all interconnected. Am I right in that
assumption and would these type of devices work over that sort of distance?
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
ashg
posted on 5/12/13 at 10:59 AM |
mine does and the garage is right down the bottom of the garden.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
mcerd1
posted on 5/12/13 at 11:02 AM |
how about just running an actual network cable ?
it will cost about the same, its pretty much guaranteed to work at that kind of distance
a couple of these:
http://www.screwfix.com/p/philex-rj45-module-outlet-kit-single-cat-5e/10030
some of this:
http://www.screwfix.com/p/philex-data-cable-cat-5e-utp-50m-beige/10218#product_additional_details_container
and one of these to make putting it together really easy (cheaper non-trimming one are available, but this really does make it easy)
http://www.screwfix.com/p/philex-auto-trim-idc-impact-insertion-tool/67391
after asking on here I ran a couple of cables around the house and after routing the cables it was a dead easy job even for me (I'd never done
it before and I'm a total muppet with wiring stuff...)
took me about 10min to wire each plug - but me being colour blind doesn't help so you'l be able to do them much quicker lol
the colour coding is on the packets for the tool and connectors etc so you don't need to know anything about it really
i also got myself a crimping tool, lots of ends and a cable tester and went nuts making loads of patch cables with the leftovers - so much cheaper
than buying pre-made
(although I should have got some stranded core cable for them, but they do work)
[Edited on 5/12/2013 by mcerd1]
hkp57
posted on 5/12/13 at 11:49 AM |
Dave
Dave my garage is about 200 foot away and it works great, long as your garage is fed from the same incomer as your house its fine.
Buy a pair of
These then you can either plug a computer directly to it or add another wireless router in your garage.
posted on 5/12/13 at 12:49 PM |
Done this a dozen times:, networking over mains from router to wireless access point up stairs.
I tend to choose older D-Link wireless access points (can be found very cheaply on EBay) because these have screw on aerial sockets which allow
fitting high gain directional external aerials.
[Edited on 5/12/13 by britishtrident]
Acc8braman
posted on 5/12/13 at 01:44 PM |
Get one of these, wireless repeater, works a treat and dead easy
Wireless Repeater
[Edited on 5/12/13 by Acc8braman]
dhutch
posted on 5/12/13 at 01:48 PM |
If its only 30ft, why not just get a wireless access point and using it as a repeater to cover the garden?
That what we did at my parents, one in the living room by the phone socket, one in the attic, covers the garden, garage and half the street!
http://www.ebuyer.com/store/Networking/cat/Wireless/subcat/Access-Points
Most will use PoE (the reverse of what you asking about, so just a single wire to it if needed.
Daniel
dhutch
posted on 5/12/13 at 01:49 PM |
beaten to it again!
whitestu
posted on 5/12/13 at 01:51 PM |
The powerline adapters work brilliantly. My office is about a 120 foot cable run via 3 distribution boards an the BB works just like it was plugged
straight into the router.
I use the tp-link ones.
Stu
Acc8braman
posted on 5/12/13 at 01:56 PM |
beaten to it again!
Quick as a fox
