macspeedy
posted on 7/11/04 at 06:27 PM |
password nerdy question
i am running windows 2000 prof and iam intested in resesting the password overide so when i log on the password pops up which it used to, any ideas
would be cool!
alister667
posted on 7/11/04 at 06:46 PM |
You could try to go to the control panel, go to 'Users and Passwords' right click the user you want to make login and select properties.
Maybe try resetting the password for that user?
I don't want to monkey around with my own settings (!), but it's somewhere to start looking.
All the best
Ali
http://members.lycos.co.uk/alister667/
posted on 8/11/04 at 09:44 AM |
Do you mean you have auto-login enabled currently, but you want to be able to type in username and password manualy?
If so, piece of cake.
1) Go to Control Panel, Users and Passwords
2) Click to set the "Users must enter a user name and password to use this computer" check box.
3). Click the Advanced tab.
4). Click to set the "Require users to press Ctrl-Alt-Del before logging on" check box.
Et voila, no more auto login.
macspeedy
posted on 8/11/04 at 10:15 AM |
i want to re activate auto login for accessing/ logging on to web sites
ned
posted on 8/11/04 at 11:06 AM |
sounds like a setting in ie, cookies/autocomplete or similar...
Ned.
beware, I've got yellow skin
ReMan
posted on 12/11/04 at 11:45 PM |
So you want your PC to ask for name and pwd before it will connect to internet, or NOT ask. Or is it logging into windows itself at start up?
macspeedy
posted on 12/11/04 at 11:49 PM |
when you go to log onto this site it remebers the username, it used to remember the password also but in an option window that comes up this was
disabled i want to disable this.. make sense? i am the only user of this computer so i don't mind it filling in the password.
Deckman001
posted on 13/11/04 at 10:53 AM |
try typing in the wrong password, then when it asks you again type the correct one in and it should ask you if you want it to remember the password
for future use
Jason
stevebubs
posted on 13/11/04 at 12:42 PM |
Turn off "autocomplete"
