jlayton
posted on 27/10/15 at 09:43 PM |
oil cooler fitting
Just fitted a mocal 13 row oil cooler to my r1 turbo Indy, using a sandwich plate none stat. Primed the lines start car up and all is fine now every
know and then the oil light comes on but there's plenty of oil in there. I have mounted the cooler with the outlets on the bottom of the cooler,
and read somewhere about an oil lock? Is there any thing I could of done wrong .
(Oil was just under maximum mark) and run a scavenge pump . So do I overt full it ...
Dingz
posted on 27/10/15 at 10:11 PM |
If the ports are on the underside how will the air get out? Suggest you turn it the other way up.
went on and on.
adithorp
posted on 27/10/15 at 10:20 PM |
Is this the oil light on the R1 clocks (thats a level light) or have you got an aftermarket pressure operated one fitted? The R1 presure (like a lot
of bike motors) can drop to 5psi at idle and would trigger most pressure lights.
http://jpsc.org.uk/forum/
bi22le
posted on 27/10/15 at 10:25 PM |
Rad ports should be at the top or the rad will air lock. Unless you have a bleed valve at the top but mocal ones don't
On tick over the oil pressure is low on becs as already mentioned. My gsxr bec used to flicker the digidash lite 2 on when it was warm.
Please read my ring story:
jlayton
posted on 28/10/15 at 07:07 AM |
Yes it's the standard light on the r1 clocks
jlayton
posted on 28/10/15 at 07:10 AM |
I also had a look on the net and people have mounted them with the outlets at the bottom, but they said you need to get the air out. So could I take
it off turn it the right way and let it run for a while on the drive then flip it back over and bolt back up
posted on 28/10/15 at 07:20 AM |
Mocal say
" Oil coolers may be mounted anyway up and are self bleeding, the resistance to oil flow through the matrix means that tanks will fill up evenly
pushing out the air before the oil flows through."
jlayton
posted on 28/10/15 at 07:24 AM |
Thanks . As it is the std r1 clocks Which is ment to be a oil level light. Maybe the oil was slightly low as it was just under the max Mark and like I
said run a scavenge pump etc. My drive is on a hill also.
adithorp
posted on 28/10/15 at 07:48 AM |
Even in the bike the oil level light is known to come on while riding (do a search on r1 forums). Where is the scavenge pump pumping to/from?
CosKev3
posted on 28/10/15 at 09:23 AM |
My outlets are on the bottom and as Mocal state,it filled up without issue.
jlayton
posted on 28/10/15 at 10:14 AM |
The scavenge pump is sucking the oil from the turbo return and putting it back into the oil fill hole on the clutch side. So maybe I need to over fill
it slightly
CosKev3
posted on 28/10/15 at 10:18 AM |
So your not running any overfill at all?
Pretty sure all R1 engines when fitted in cars need some overfill,presume you've got a baffle plate fitted?
In my 4XV R1 I fill the oil to the top of the sight glass with the engine idling at normal temp.
jlayton
posted on 28/10/15 at 10:28 AM |
Yeah I have a baffle plate, il over fill slightl.y when I can chance and see how I get on thanks
CosKev3
posted on 28/10/15 at 10:37 AM |
You can overfill by 500ml.
Presume you've got a catch can fitted?keep an eye on that and if it starts filling with oil don't overfill as much.
adithorp
posted on 28/10/15 at 12:02 PM |
Are you checking the oil level when idling? The best check/level when in a car has been found to be... Engine hot and idling, level 2/3-3/4 way up the
sight glass.
With the oil cold, the light will often come on... and at high revs even hot... and when the oil gets old... and whenever it feels like it! Mine
has been on all the way from Monaco to Manchester with no detriment; you'd be stopping every 10mins to check the level if you paid any attention
to it.
It's only any good as an indication of level after a few seconds of idling. It's so unreliable when driving, that I altered mine (with a
relay) so its only operates when the hand brake is on. Fit a pressure guage and rely on that.
jlayton
posted on 28/10/15 at 01:01 PM |
I usually run the car so it gets hot shut it off and then check the oil level. Think I'm b enable to sort it now. Thanks for all your help
adithorp
posted on 28/10/15 at 01:53 PM |
quote: Originally posted by jlayton
I usually run the car so it gets hot shut it off and then check the oil level...
Then you're oil will be too low for car use, the light will often come on and you'll risk oil starvation cornering. Nothing to do with the
scavenge pump or the cooler.
jlayton
posted on 28/10/15 at 03:34 PM |
Ok so it's best that I check it when car is idleing and it should be 3/4 full on sight glasd.....
Thanks again
