perksy
posted on 8/2/16 at 03:06 PM |
Garage Lighting
Time to replace the old twin 6' tube lighting in the garage
These are the old fat type tubes
Have 2 x 6' twins at the moment plus a few singles
What are my options and where to buy from ?
Don't mind going used/secondhand if it will help keep the cost down
posted on 8/2/16 at 03:12 PM |
Interesting change.
At home I've been around the house and changed to low power LED bulbs. It's cost some to do, but in theory the bulbs last longer and use
a lot less power to keep the leccy bills down. I've also been "instructing" the family to turn the sodding things off when
they're not in the room - harder than it sounds to impart this knowledge!
In my garage I've fitted LED bulbs as well and I believe you can get LED strip light bulbs as well. May impose more initial cost, but safe in
the knowledge that running costs will be lower.
HowardB
posted on 8/2/16 at 03:23 PM |
I have some 500W halogen security heaters, I mean lights for winter,. bloody magic. Otherwise yes LED down lights are good
Howard
posted on 8/2/16 at 03:32 PM |
I've found these guys pretty good via their local trade counter and online.
https://www.ledhut.co.uk/
posted on 8/2/16 at 03:36 PM |
Something else I've found very helpful in the garage is a lead light to get illumination right where you need it.
Ugg10
posted on 8/2/16 at 03:47 PM |
I was looking at these for my garage - LED strip lights that can be daisy chained together. Price looks OK in the grand scheme of things.
https://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/Ultra_Slim_KBU/index.html
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
furryeggs
posted on 8/2/16 at 04:31 PM |
I've got 2 twin strip lights on the cieling, 2 old 800w security flood lights pointing at the car and under counter leds on the cupboards. With
the heating/air con on aswell the rest of the village goes dark.
loggyboy
posted on 8/2/16 at 04:46 PM |
Unless your after new tech - good ol' toolstation works for me!
http://www.toolstation.com/shop/Lighting/d220/Batten+Fittings/sd3342/Fluorescent+Batten+Fitting+LPF/p56581
Mistral Motorsport
posted on 8/2/16 at 07:34 PM |
Not sure its worth going LED in a garage unless you spend a serious amount of time there. I went LED in the garage just because I'm restricted
to 12v lighting (no mains) so efficiency was important. But if you've got mains I'm not sure it's worth it. We changed our fluro T8
lamps to LED at work and the break even time was a year but then they're on 10 hours per day five days a week....
PAUL FISHER
posted on 8/2/16 at 07:52 PM |
Ive fitted some of these 12v leds in my garage with good results, I run them through a 240v to 12v driver, fitted 12 of them, total cost less than
£50.
And they only use less than 120w total.
4/8x 50CM 36 LED 5630SMD 9W Aluminum Shell Rigid Hard Strip Bar Light Lamp DC12V
[Edited on 8/2/16 by PAUL FISHER]
PAUL FISHER
posted on 8/2/16 at 07:55 PM |
[img]
![](/galpreviews/20151123_223515_St Annes View.jpg) ![12volt led lighting installed](/gallery/20151123_223515_St Annes View.jpg) 12volt led lighting installed
[/img]
samjc
posted on 8/2/16 at 09:44 PM |
Im getting some led batterns from screwfix to try as i wanted to just change to let bulbs but turned out cheaper to buy a complete new fitting with
bulbs.
matt5964
posted on 9/2/16 at 07:22 AM |
http://www.neweysonline.co.uk/5ft-70w-twin-standard-led-batten-7000lm-5000k/1052080303/ProductInformation.raction
I've got 4 of the above in a double garage, light is amazing and pure white very good to work with. Didn't pay anything near website price
as I work for revel group.
Guys on trade counter will do you a deal. Commercial spec luminary so are so much better than the normal stuff.worth the extra imo
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
hughpinder
posted on 9/2/16 at 11:21 AM |
I recently fitted a 30W led floodlight to replace a 500W halogen - gives the same light, but a much wider spread of light (so about 4 times the area
is evenly lit). It cost about £40. I have 3*3w floodlights in my greenhouse (27ft by 12ft) and it is the best lit room in our house!
mcerd1
posted on 9/2/16 at 11:36 AM |
Just to ask the stupid question (its what I'm best at ) have you painted the walls / floor / roof in light colours first?
Its amazing how much difference it can make and how many fewer lights you can get away with
matt5964
posted on 9/2/16 at 11:39 AM |
Yes I painted the walls and celing in white, floor is garage PVC tiles in mid grey, and as you say makes a bug difference
coyoteboy
posted on 9/2/16 at 01:01 PM |
I'm now running 4x 5ft strips evenly spaced about the roof.
It's lovely.
I can't emphasise how nice it is to have light from all angles.
Chris_Xtreme
posted on 9/2/16 at 05:38 PM |
depending on how dry your garage is, you may want to consider waterproofed options. mine has a flat roof - metal and condensation dripping is an
issue..
tho - why do you want to replace them? if they aint broke....
jacko
posted on 9/2/16 at 06:21 PM |
we fitted 4 new led strip lamp in the work shop they are a white/ blue light and bloody awful and if you look at them they leave blue rings in your
eyes
i have asked the electrician to change them
jacko
