MsD
posted on 17/2/16 at 09:34 PM |
WTD- Zetec RWD conversion bits.
After my pinto spun a shell I'm thinking (still not 100% committed!) of converting my car to zetec power
I've not decided on 1.8/2.0 black/silvertop yet so I'm open to allsorts.
Water rails, clutch/ flywheel assy's, ignition, injection/carbs, sumps.
What have you got?
Mark.
bi22le
posted on 17/2/16 at 11:05 PM |
I think someone posted very recently about breaking a half finished kit with everything needed included.
The box got sold but the engine was still up for grabs IIRC.
Please read my ring story:
stripe70
posted on 18/2/16 at 07:48 AM |
I`ve recently upgraded to a blacktop.
Still got my old 2.0 silvertop for parts, i was going to start selling off soon.
Coil pack, cut & welded alloy sump & pickup, water pump, head and std cams, rocker cover etc
The only thing wrong with it was low compression. Pretty sure it was piston rings
kingster996
posted on 18/2/16 at 08:24 AM |
I have an st170 engine and some hayabusa throttle bodies with spacer kit to suit st manifold. Engine has no ancillaries other than inlet manifold and
injectors/rail/loom.
[Edited on 18/2/16 by kingster996]
I used to be indecisive, but now I'm not so sure
Shooter63
posted on 18/2/16 at 09:39 AM |
I've PMed you about the bare engine.
Shooter
furryeggs
posted on 18/2/16 at 12:35 PM |
I have a complete 2.0 flywheel with brand new clutch and pressure plate 1" 23 spline shaft, and a 17 spline clutch and pressure plate (older
zetecs, escort etc).
