madteg
posted on 26/11/16 at 08:44 PM |
New track car project
Just started building a track day car. Have got a 1200 Kawasaki engine and going to do a close as i can copy of the car from. Ludermann engineering
https://ludemannengineering.com/ Have a look and let me know what yo think. Its well worth a Look
ettore bugatti
posted on 26/11/16 at 09:32 PM |
Thanks for the link!
Now, I have 2 extra projects to follow on line.
JimSpencer
posted on 26/11/16 at 10:32 PM |
Hi
Looks very interesting, it'll be a fun project.
Only thing I'd ensure is that the Build meets the UK specifications too - roll hoop being the obvious bit (Major issue in UK clubby motorsport
at the minute) this needs to be 42.4mm tube with a 2.6mm wall thickness or the standard imperial equivalent with twin backstays of 26mm or 1 inch -
all from low carbon CDS.
The trackdays you'll be able to run it at might be a bit thin on the ground but it should be eligible for Monoposto and sprints / hillclimbs
too.
It might be worth considering dropping it to a ZX10 rather than the ZX12 as the class structure in both of the above see's the ZX12 in no mans
land, hills is up to 1100 then 1101 to 1600, Monoposto is up to 1000, then 1001 to 1400
Or you could upgrade to a ZX14 of course
Bear in mind that it'll be devastatingly quick, nothing else you'd come across on most trackdays would get even close, even with mudwings
nailed on!
Mash
posted on 26/11/16 at 10:47 PM |
Nice job, I like Pit Girl too
Feel like moving out there
adithorp
posted on 26/11/16 at 11:39 PM |
Bear in mind that many/most trackdays aren't allowing single seaters or open wheels.
http://jpsc.org.uk/forum/
Rosco86
posted on 27/11/16 at 07:50 AM |
very nice
My Build Thread
russbost
posted on 27/11/16 at 08:22 AM |
Don't know if either of these threads might help
Link 1
Link 2
Or, alternatively I have a no. of second hand or slight second Furore bodypanels that might save a lot of fabrication
Make sure you keep us updated on the build
mark chandler
posted on 27/11/16 at 01:15 PM |
I do feel you will struggle to find anywhere to run it unless competively, I have never been on a track day where open wheels have been allowed apart
from Lyden hill 12 years ago and that was class runs, 15 minutes per hour.
This put paid to my ambition for a single seater.
russbost
posted on 27/11/16 at 04:18 PM |
So put a set of wheel arches on, I've run the Furore at a track day without a problem
