cosmicicecreamman
posted on 4/4/19 at 08:39 AM |
Sierra tripod outer CV joints - where to buy new
Hello all,
Does anyone know where you can buy new outer Sierra tripod CV joints? I have bespoke driveshafts and would like to fit new tripod CV joints rather
than changing the cans over and re-using.
If anyone has a link / part number / knows of where to get them I would really appreciate it.
Many thanks
Stephen
posted on 4/4/19 at 09:09 AM |
Do you mean these ones?
posted on 4/4/19 at 09:11 AM |
A dated post, but this might have the part numbers you're looking for if you decide to go for overhauling...
http://www.locostbuilders.co.uk/viewthread.php?tid=11231
flak monkey
posted on 4/4/19 at 12:23 PM |
They are obsolete as far as I recall when i last asked at Ford.
Sera
http://www.motosera.com
CosKev3
posted on 4/4/19 at 01:46 PM |
Lobros for bolt on shafts are readily available
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F142606491708
[Edited on 4/4/19 by CosKev3]
minitici
posted on 4/4/19 at 02:25 PM |
You can get complete 2.0 drum brake shafts with CV joints, new from J & R.
You could salvage the outer CV's from these (these ones have rubber boots and solid housings rather than the metal cans).
https://www.ebay.co.uk/itm/FORD-SIERRA-2-0-PETROL-DRIVESHAFT-OFF-SIDE-CV-JOINT-1982-1993/141023774201
posted on 4/4/19 at 02:27 PM |
Could well be, I got mine from the local Ford main dealer, but it was 15 years ago now!
ianhurley20
posted on 4/4/19 at 09:25 PM |
Another vote for J&R in Brum - very good indeed and good value
motorcycle_mayhem
posted on 5/4/19 at 08:15 AM |
Hellishly expensive way to do it, but I converted a Ford lobro set up to tripode using GKN bolt on joints and Quaife output flanges.
This was on a Fiesta (IB5) set up. I have No idea if the Sierra is the same, perhaps someone will confirm that, it'd be good to know.
http://race.parts/Catalogue/Drivetrain/Tripode-Joints/Tripode-Housings
https://shop.quaife.co.uk/f7z432
I still wince at what all this cost, but it hasn't broken (yet).
cosmicicecreamman
posted on 8/4/19 at 11:33 AM |
Yes, this is what I'm looking for.
I think the best thing to do would be contact J&R directly and see if I could send them my driveshaft and have the new tripod CV fitted (assuming
they assemble the driveshafts that they sell in house).
Many thanks for all the replies
Stephen
posted on 8/4/19 at 02:07 PM |
You can assemble them yourself if you can get the bits. Worth noting the joint is sprung and you have to peen the replacement metal cans in place. I
found it best done with the spline end part held in a vice and pushing along the shaft to hold it all in place whilst preening the can.
