Author: Subject: VW engine to a ford box
Edsanutcase
posted on 2/5/05 at 05:25 PM Reply With Quote
Can anyone help! I want to replace to pinto with a 16v golf engine? Or poss a 20v turbo!
posted on 2/5/05 at 08:29 PM Reply With Quote
This comes up from time to time, as does the Pug GTi engines. The general opinion seems to be that you'll need a custom design/manufacture bell housing or bell housing adapter to mate the engine to a Ford box.
Adapters for more commonly used engines like the Vauxhaul XE and Toyota 4AGE are readily available at a cost.
Do/Did VW/Audi etc make any suitable RWD boxes?
Nick
clbarclay
posted on 2/5/05 at 09:11 PM Reply With Quote
The only rear wheel drive VW/audi group vehicles I can think of are vans/minibuses and the 924. Whether or not thier gearboxs would fit latter engines is another problem.
owelly
posted on 2/5/05 at 10:25 PM Reply With Quote
Nothing is impossible........
This plops an Alfa V6 onto a Ford T9
http://www.ppcmag.co.uk
posted on 3/5/05 at 08:09 AM Reply With Quote
not impossible, but probably quite expensive
James
posted on 3/5/05 at 09:07 AM Reply With Quote
Are they not a little tall for a Locost?
James
Noodle
posted on 3/5/05 at 11:58 AM Reply With Quote
I think these chappies have been fitting Audi/VW motors to Locost's : http://www.racetech.ee
Drop them a mail and see what they say..
Neil.
Your sort make me sick
scotty g
posted on 3/5/05 at 03:11 PM Reply With Quote
Sure i saw a VW powered 7 on ebay recently, don't know how to do links so even if i found it i couldn't show you. Sorry.
chrism
posted on 3/5/05 at 04:18 PM Reply With Quote
I think there has been an article in Practical performance car about making your own adaptors, not sure which issue it was in but they mentioned in Issue 7 that it would be in a later issue.
A little hard work never killed anyone, but why take the risk!
alfasudsprint
posted on 3/5/05 at 06:19 PM Reply With Quote
Thought I should chime in as I'm using a VW engine. Its a brazilian AP, extremely tuneable (in excess of 140bhp after a head job, angles on vavles, new camshaft and bigger carb) it was originally based on the VW Germany engine put into the 924....its very similar to latest golf/polo block, so much so that the head off the golf (crossflow) will go straight onto my block. As for height, I increased the scuttle 1 inch, and the bonnet at that point, theres a hole for the filter in the bonnet too, poking throuhj about 20mm max, looks pretty good. Remember its on a carb, injection may change that and the induction system is on the other side to mine, exhaust the same. Go for it!
alfasudsprint
posted on 3/5/05 at 06:36 PM Reply With Quote
Forgot to say I chopped the sump quite a bit too, necessitating an oil cooler to increase oil capacity just in case. Look at the estfield site, especially here http://www.racetech.ee/a/images/vw_2,0_01_2004/web2/p5100154.jpg
for a pic of VW 16v lump with Lada running gear!!!
Tim
dblissett
posted on 3/5/05 at 07:25 PM Reply With Quote
vw/t9
i have seen a dutch company put vw engines in a 7 type car i think its called a donkervort not sure of the spelling tho
they must be using a rwd box they look very well put together
dave
Edsanutcase
posted on 3/5/05 at 09:50 PM Reply With Quote
vw to t9
Thanks chaps! I will get on with it and let you know.
trevorc
posted on 7/8/06 at 02:11 AM Reply With Quote
did you ever find out if there was an adapter available ??
trevorc
posted on 7/8/06 at 02:12 AM Reply With Quote
what transmission did you use ??
NS Dev
posted on 7/8/06 at 09:18 AM Reply With Quote
FAR from it!
As Owelly hasn't answered I will for him! That white bellhousing was a DIY jobbie made in steel for a cost of a few quid, "can-do" engineering at its best, and extremely cheap with it!
8smokingbarrels
posted on 8/8/06 at 12:49 PM Reply With Quote
NS you are quite right!
The bellhousing was featured in PPC mag a couple issues ago. Really nice piece of kit- and cost very little
I'll get the issue number if anyone needs it.
chris
Piledhigher
posted on 18/8/06 at 12:10 PM Reply With Quote
vw bellhousing
Just found this link at the US Locost site.
Cory
http://www.tigersportscars.nl/Bellhousings.htm
daKlone
posted on 18/8/06 at 02:29 PM Reply With Quote
chris
I'd be interested in that if it's not too much trouble to dig out.
dK
Winter is coming...
goodguydrew
posted on 3/9/06 at 08:00 AM Reply With Quote
The "bellhousing" issue is PPC Dec 2005. There is one on ebay right now.
coxylaad
posted on 5/9/06 at 09:59 PM Reply With Quote
in that case can you not use the 924 transmission setup? that was rwd?
Ian
Marcus
posted on 6/9/06 at 08:00 AM Reply With Quote
The 924 had a transaxle, ie gearbox at the back, so no use for Locost.
Marcus
Because kits are for girls!!
mcerd1
posted on 7/9/06 at 07:45 AM Reply With Quote
I think I saw something in PPC mag about using Volvo boxes for AUDI engines ???
I'll check
