Author: Subject: Editing the registry.
Rorty
posted on 5/5/05 at 12:39 PM Reply With Quote
I'm in a bit of a spot. I have a program which is about to expire and I really don't want it to! I haven't a clue about editing the registry, though I have located what I suspect is the item that is responsible for the programs imminent demise.
Of course, I could be totally mistaken and could be barking up the wrong tree.
However, rather than damning myself over the net, could one of you young puter whizzes email me and talk me through the editing bit if it is indeed possible to do it?
Just add .com to this email address to complete it:
info@rorty-design
Cheers, Rorty.
flak monkey
posted on 5/5/05 at 12:48 PM Reply With Quote
Theres a program called regcleaner which is useful for cleaning your registry. Can be found here:
http://www.worldstart.com/weekly-download/archives/reg-cleaner4.3.htm
Be warned that a lot of the limited trials programs time limits are now not linked to the registry entries. And removing them will not stop it expiring. (Program developers are getting wary to tricks like that). Some programs even if you uninstall and remove all reg entries you can find, will still not work if you reinstall them.
[Edited on 5/5/05 by flak monkey]
Sera
http://www.motosera.com
Rorty
posted on 5/5/05 at 02:00 PM Reply With Quote
Thanks Flak. I installed RegCleaner recently on the advice of someone on another thread (probably you!), but I'm still afraid of editing the registry because I'm a dumbass and I'm afraid of doing more harm than good. There is a thing waiting in the wings called karma!
Cheers, Rorty.
posted on 5/5/05 at 02:35 PM Reply With Quote
Karen's registry prune is quite good for saving parts of the registry as backups see.
http://www.karenware.com/powertools/ptregrip.asp
flak monkey
posted on 5/5/05 at 03:09 PM Reply With Quote
Regcleaner backs up any changes you make so that they can be undone. Basically any entry that is related to programs you know you have installed will be fine to remove. (Though the program may not work afterwards, most will as they just recreate lost registry entries!) Dont be afraid of the registry, especially with regcleaner. Basically the simple rule is, if you know what it is, then you can delete it (if you want to), if you dont know what it is, leave it alone!
Regcleaner is also good for removing programs from startup...
Sera
cerbera
posted on 5/5/05 at 04:41 PM Reply With Quote
If I may ask, what is the program as there maybe a hack or crack to be found for it.
