Author: Subject: Netgear DG834g
Ian Pearson
posted on 19/7/05 at 11:35 AM Reply With Quote
Netgear DG834g
I've a DG834G wireless router. The signal strength is good in parts of the house, but as some of the wall are 3ft thick, the signal tails off, and I lose the connection. I've been told there are range extenders and directional antenna that will make a difference. Would any of you have any advice!
Regards, Ian.
DaveFJ
posted on 19/7/05 at 02:00 PM Reply With Quote
It's going to get very expensive if you need to transmit through that much stone (guessing stone walls)
If at all possible I would suggest a cabled 'backbone' linking a two or more wireless routers in strategic locations.
failing that repeaters and larger aerials / more powerful wireless transmitters are available but will cost!
I have a DG834g at home at the moment and it barely manages to cover a small 1930's 3 bed semi so it doesn't stand a chance with your property.
Dave
