piddy
posted on 30/12/05 at 06:47 PM |
broadband filters
Hi.
Is there a way to tell if a Broadband filter is still working.
posted on 30/12/05 at 07:37 PM |
If you're still on broadband it's working.
flak monkey
posted on 30/12/05 at 07:49 PM |
If you can use the net and the phone at the same time then its fine...
Sera
http://www.motosera.com
posted on 30/12/05 at 09:00 PM |
The filter is for voice analogue line -- nothing to do with the actual broadband side it just cleans the broadband "hiss" from your
oridinary phone. One socket on the filter is filtered (for the telephone) the other is straight through (for broadband).
All phones or fax should pass through a filter the broadband itself dosen't need one. If you share a filter between extensions using a splitter
adaptor it is important that the broadband is not connectect through the filtered side of any fillter.
Full explanation http://www.zensupport.co.uk/knowledgebase/article.aspx?id=10013
Trouble shooting
http://www.zensupport.co.uk/knowledgebase/article.aspx?id=10012
[Edited on 30/12/05 by britishtrident]
