chrisg
posted on 21/1/06 at 05:51 PM |
Sketchup help.
Can any one tell me how to cut holes in sketchup?
Thanks in advance
Chris
chrisg
posted on 21/1/06 at 08:30 PM |
used a hole saw, made a mess of the monitor.
Nearly as bad as when I was using the tippex in "Word"
Chris
CommanderAce
Like this?
Roads? Where we're going we don't need roads!
greggors84
posted on 21/1/06 at 08:31 PM |
Draw a circle on the surface you want a hole in and then pull it downwards so that it removes the material. Assuming you want a circular hole that
is...
Edit: Just tried it and it works
[Edited on 21/1/06 by greggors84]
Chris
The Magnificent 7!
CommanderAce
posted on 21/1/06 at 08:37 PM |
Now even bigger and bader!
greggors84
posted on 21/1/06 at 08:42 PM |
Always trying to go one better!
What program you use to turn that into a gif? Im guessing you didnt do loads of screen dumps!
Chris
The Magnificent 7!
CommanderAce
posted on 21/1/06 at 08:53 PM |
Bulent's Screen Recorder to capture what I did into an AVI file which was promptly turned into a gif with the help of 123 AVI to GIF Converter
chrisg
posted on 22/1/06 at 01:52 PM |
Thanks mate!
When you select the face inside the circle how do you remove it?
I'm so very stupid.
Chris
