Jasper
posted on 20/2/06 at 03:25 PM |
File name case changer software?
I need a bit of software to batch convert file names and extensions from Upper to Lower case.
Any ideas?
flak monkey
posted on 20/2/06 at 03:53 PM |
Not tried it, but will this do what you want?
http://www.replsoft.com/casecnv.html
Sera
http://www.motosera.com
Jasper
posted on 20/2/06 at 04:12 PM |
Had a look, seems complicated and I can't get it to do want I want - thanks for trying though
Tangerine Scream
posted on 20/2/06 at 05:35 PM |
I've tried this a couple of times...
http://www.finebytes.com/mfr/
HTH
Surrey Dave
posted on 20/2/06 at 06:19 PM |
FREE demo her you could try..........
www.123renamer.com
I have used it before...........it worked for me.
Gav
posted on 20/2/06 at 06:56 PM |
What exactly do you want it todo?
im sure i could probably knock something together for you if its not too complicated.
Jasper
posted on 21/2/06 at 10:45 AM |
I'll try those, thanks chaps.
All I want to do is put in lower case the file names of images I then put on my web site, as the web site only likes lower case names, and many of my
suppliers use uppercase names for the images.
I also need it to change the case of the file extension, in this case .JPG to .jpg when necessary for the same reason.
chockymonster
posted on 21/2/06 at 02:22 PM |
Very easy to do in vbscript.
create a new text file.
Paste the following text into it.
code:
set fso = createobject("scripting.filesystemobject"
Function GetPath
path = WScript.ScriptFullName
GetPath = Left(path, InstrRev(path, "")
End Function
path2 = GetPath
folder = Left(path2, (Len(path2)-1))
set folder = fso.GetFolder(folder)
set files = folder.Files
s = ""
vCount = 0
for each file in files
vCount = vCount + 1
ReDim Preserve arFiles(vCount)
Set arFiles(vCount) = file
tempfilename = LCase(arFiles(vCount).name)
file.name = "temp" & vCount
file.name = tempfilename
next
save the file as casechange.vbs
copy the file into the folder that has the files in it you want to change.
open a command prompt window and change to that folder.
type code: cscript casechange.vbs
If you want me to explain what it does then no problems, otherwise it will step through every file in the current folder changing every upper case
letter to lower case without you needing to do anything!
Gav
posted on 21/2/06 at 02:25 PM |
Here's something i knocked up while i was having my lunch.
Should be fairly self explanitory.
Surrey Dave
posted on 21/2/06 at 10:58 PM |
Looks good but did not work for me..........couldn't click the OK after selecting file or folder....
[Edited on 21/2/06 by Surrey Dave]
Gav
posted on 22/2/06 at 01:31 PM |
Would that be the program i knocked together?, as ive just downloaded it and it seems to work ok for me
Jasper
posted on 23/2/06 at 06:52 PM |
Don't think I'm not appreciative I'm off work for a couple of days - I'll give it a go tomorrow ....
