Humbug
posted on 28/2/06 at 02:51 PM |
Anyone got a PC running Windows 98?
My old PC ran Windows 98, new one (about 18 months old) is XP. At the time I copied "everything" I would need to the new PC... except for
some obscure files that were backed up to CD using W98 Backup... Guess what - it is not possible to restore those to Windows XP. I need to get hold of
some files.
Checking out various sites it seems that there is no utility in Windows XP to restore from these old backups (with QIC extension). I found a package
called Backup MyPC which is claimed to be able to do it, but the trial versions certainly doesn't (it says I have to have made the backups with
the same software to be able to restore...)
So - has anyone nearish to me got a PC still running W98 that I could come and use to restore these files? I have a bunch of backups on CDs that need
to go hrough to find the files to restore.
Thanks in hope
Gav
posted on 28/2/06 at 03:20 PM |
Failing anyone near you with a W98 pc an option you could look at is downloading the demo version of VMWare and installing a copy of windows 98 into
that virtual machine and then mounting your cd inside the virtual machine and restoring your files that way then copying them from the virtual
machine.
if you want anymore info on how to do it let me know.
[Edited on 28/2/06 by Gav]
Humbug
posted on 28/2/06 at 03:48 PM |
machine.
Might be useful, as long as it doesn't feck up my new PC! I still have the old W98 CD, but I am not sure if it will install to a different
machine?
Scotty
posted on 28/2/06 at 04:32 PM |
hi
have a couple of old pc's with win98
installed, can you send/ email/whatever and i'll have a go for you
oops, sounds like you have a loty of files there, i'll restore all the cd's and write them to dvd's for you if you post them down
[Edited on 28/2/06 by Scotty]
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
Gav
posted on 28/2/06 at 06:23 PM |
Looks like scotty might be able to help you, and yes you would be able to install w98 onto the virtual machine that VMWare creates and after its all
done you can remove VMWare, just like any other program.
posted on 28/2/06 at 07:39 PM |
The old trap --- not the first time MS have done it --- MS were made aware of the problem at the time of Xps launch they claim " This
behavior is by design."
Would offer the loan of a PC but much too far away.
For anyone wanting a really good genuinely free backup program that will even back up to and restore from your webspace by FTP and SSL and uses Zip
file formats try Cobian Backup
http://www.educ.umu.se/~cobian/cobianbackup.htm
greglogan
posted on 1/3/06 at 01:19 AM |
I'm a bit far away from you too, but I have a cople of old PCs that run Win98. I used to keep a PC with all the versions of Windows on it so I
could boot between different versions if someone I had sold a Pc to had problems with it. If I can help, let me know.
Women are meant to be loved, not understood.
Scotty
posted on 1/3/06 at 05:28 PM |
i assume thats a "no thanks" then ?
Humbug
posted on 1/3/06 at 09:44 PM |
Scotty - sorry I didn't get back earlier. Thanks for the offer - I'm trawling round neighbours etc. to try to find someone a bit closer to
home, but if that is not successful, I will give you a shout.
Scotty
posted on 2/3/06 at 08:47 AM |
no probs mate
i run a computer shop so always have win98 computers around
Humbug
posted on 2/3/06 at 10:32 PM |
Found a PC with W98, so I will hopefully be able to restore my files.
Thanks again, Scotty
Scotty
posted on 6/3/06 at 02:57 PM |
yw, but the offer still stands if needed
Humbug
posted on 6/3/06 at 07:17 PM |
It worked OK, but thanks again
