Author: Subject: svchost.exe
dave1888
posted on 26/6/06 at 03:57 PM Reply With Quote
svchost.exe
Anyone know what this is and why is it using so much of my cpu resourses.
graememk
posted on 26/6/06 at 03:58 PM Reply With Quote
The Svchost.exe file is located in the %SystemRoot%\System32 folder. At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services permits better control and easier debugging.
google it theres quite a pagies to read over.
[Edited on 26/6/06 by graememk]
posted on 26/6/06 at 04:56 PM Reply With Quote
.....has that helped?
joneh
posted on 26/6/06 at 05:08 PM Reply With Quote
It may be a virus as some pleb created one like this. Run adaware, ccleaner and a good virus scanner. All free, just google for them.
You may want to edit the registry, as svchost takes a lot of information from there, and if its full of junk it can slow things down.
hth.
posted on 27/6/06 at 08:08 AM Reply With Quote
hth.
Available from our website...
