Author: Subject: No internetty on sons pc
donut
posted on 23/9/06 at 08:17 AM Reply With Quote
My son has been away all week and on his return we have found that he has no internet. We have broadbean in my office which is routed to both my boy's bedrooms.
When you open explorer it tries to go to an MSN page and comes up with the 404 error on any address you put in. I have checked the cables and all is well. My other son's pc is fine so the signal is getting to the splitter.
Any ideas? I could try pinging the server but i don't know how and even if i did i would'nt know how to fix it.
ecosse
posted on 23/9/06 at 08:35 AM Reply With Quote
If you haven't tried already, reboot everything including the BT router.
If that doesn't help look at your sons PC for the fault (presuming all the others can work okay) check network card first, is it enabled and does it have an IP address?
If not, are there any lights on at the point where the cable plugs in to the PC?
Is the network device okay in windows device properties?
Try that lot and see how you get on
Alex
chockymonster
posted on 23/9/06 at 09:30 AM Reply With Quote
if every other pc on the network is fine then it's not likely to be the router.
On one of the pc's that works click on start and run. type cmd and press return.
type ipconfig and press return
One of the lines will say default gateway and give an ip address.
go to the not working machine and click on start and run. type cmd and press return.
then type
ping ipaddressofgateway
if you get a reply then you know cables are most likely ok. If you can't then it's a cable problem.
if you can ping the gateway then it's more likely a dns problem. At the cmd prompt type nslookup
you should get something up that looks like this but with different details
code:
C:\Documents and Settings\paul>nslookup
Default Server: ith.home.chockymonster.co.uk
Address: 10.1.0.3
at that prompt type www.google.co.uk and press return.
code:
> www.google.co.uk
Address: 10.1.0.3
Non-authoritative answer:
Addresses: 66.102.9.99, 66.102.9.147, 66.102.9.104
Aliases: www.google.co.uk, www.google.com
That's what you should get back
chockymonster
then type
code:
Address: 10.1.0.3
code:
> www.google.co.uk
Address: 10.1.0.3
donut
posted on 24/9/06 at 12:24 PM Reply With Quote
Ok thanks....
I have checked the little flashing light where the cable plugs in and it is flashing away, also the splitter lights are flashing.
On the boy's machine i typed 'ping ipaddressofgateway' and got this in return:
"ping request could not find host ipaddressofgateway. please check the name and try again"
I did the same on my office machine whaich has internet access ok and got the same message.
Where do i go next. The machine was working fine before my son went away for a week, no leads were touched and all was left perfik
Any ideas?
[Edited on 24/9/06 by donut]
iank
posted on 24/9/06 at 01:16 PM Reply With Quote
did you actually type 'ping ipaddressofgateway'
or 'ping 127.0.0.1' or whatever ipconfig gave you as the IP addess?
p.s. using 127.0.0.1 will tell you if the PC network stack can see itself - it's the loopback address.
donut
posted on 24/9/06 at 03:47 PM Reply With Quote
Yes i did actually type 'ping ipaddressofgateway'
chockymonster
posted on 25/9/06 at 02:09 PM Reply With Quote
Have a read through of what I said again, sorry if I didn't make it clear, where I typed
Ping ipaddressofgateway, you need to change ipaddressofgateway to what ever the ipconfig command said the gateway was.
The machine I'm on at the moment gives it as
Default Gateway . . . . . . . . . : 10.44.68.1
so I'd type
ping 10.44.68.1
donut
posted on 25/9/06 at 02:36 PM Reply With Quote
aha! ok i'll give that a wizz
