Jasper
posted on 29/9/06 at 03:55 PM |
Locked folders problem
So I've had to copy all my iTunes music back from an external HDD using Windows Back-up. I'm running XP home edition.
I've copied them back to where they were in Documents and Setting - All Uers - My Music.
Now when I try to pull them all back into iTunes it's only importing a fraction of them.
And when I look at the folder properties they are nearly all set to Read Only. When I try to re-set to open I get 'Error Applying
Attributes...... Access Denied'.
So why is it denying me access? The back-up was done from this machine straight back to itself - I'm logged in as Administrator as I always am.
scottc
posted on 29/9/06 at 04:03 PM |
I assume you backed them up then reinstalled windows??
What you'll need to do is take ownership of the files. Click the advanced button on the security tab, the go to the owner tab, and take
ownership from there.
Then make sure the administrator has "Full Control" on files and subfolders.
Scott.
russbost
posted on 29/9/06 at 04:23 PM |
Think you'll find you have to be in "safe mode" or security is "greyed out" - I have a full set of instructions to do
this if you are still stuck.
Jasper
posted on 2/10/06 at 02:42 PM |
Scott - Nope - just wanted to get them back after accidently deleting the whole folder, not sure where you mean to click the security tab - can you be
more specific?
Russ - yes please, still stuck......
