Avoneer
| posted on 11/10/06 at 06:38 PM |
Puter won't boot
Hi Guys,
Puter won't boot.
Will start, beep , then beep, then beep and keep on beeping about every 5 seconds and that's as far as it gets.
Took out both (what I think are) memory cards from the board.
See following pics:
Avoneer
| posted on 11/10/06 at 06:39 PM |
And the other one:
Avoneer
| posted on 11/10/06 at 06:41 PM |
With Pic 1 in either slot, the computer will boot and run fine, albeit slowly and with no beep on start up.
With Pic 2 in any slot either on it's own or with Pic 1, I get the same beep scenario and a non starting computer.
Do I just need some new memory and is it plug and play?
Thanks,
Pat.
Jubal
| posted on 11/10/06 at 06:56 PM |
As far as I can tell from the pics you have two sticks of SDRAM. One is 128Mb and one is 64Mb. The 128Mb is PC133 and the 64Mb is PC100. Assuming I am
correct the cheapest option will be to buy another stick of 128Mb SDRAM PC133 which will cost very little and throw away the faulty 64Mb stick.
Here's a cheap source:
http://ebuyer.com/UK/product/19820/rb/22360263301
Although if it was my computer I may be tempted to buy 2 x 256 sticks and it will run a little faster.
| posted on 11/10/06 at 07:16 PM |
Yes it's plug and play
How many slots have you got and are they all the same. If you have room you can reuse your working stick with your new memory.
Avoneer
| posted on 11/10/06 at 07:56 PM |
It's not my computer and it has two slots.
Any reason why it doens't beep with just the working 128 memory?
Works fine though.
Pat...
ReMan
| posted on 11/10/06 at 08:37 PM |
They are the "beep codes" your getting telling you there is a problem...
http://www.pchell.com/hardware/beepcodes.shtml
Avoneer
| posted on 12/10/06 at 06:31 AM |
So sticking in a new memory stick should re-gain my beep?
Pat...
Catpuss
| posted on 12/10/06 at 07:41 AM |
Works fine though.
Pat...
Yep, the 64mb DIMM is knackered. POST test is reporting it as faulty and beeping. I had this with a stick that worked OK for 3 months then failed.
Have a look at http://www.crucial.com/uk/
They are near the cheapest and certainly the best service you will get. You can use their on line configuration screen to pick the memory for your PC.
A lot of people I know use them as the preferred supplier.
SDRAM (which I think that is) isn't too cheap anymore. Around 20 quid for a single 128mb stick, but you probably won't get a 64mb too
easily from a shop.
If you do need to get one, go for another 128. If its a SDRAM based machine I assume its fairly old, so not going to be running the lastest games at
full tilt?
Avoneer
| posted on 12/10/06 at 11:04 AM |
No, it won't be running at full tilt.
It works fine as it is with just the 128 stick, but with no beep.
Is it ok to leave it as it is even though there is no beep, or is it beeping because it needs a 2nd stick of whatever size?
Pat.
Catpuss
| posted on 12/10/06 at 05:30 PM |
With no beep and working is fine.
The multiple beeps are becuase its doing a test of the 64mb memory stick and finding an error.
If the PC doesn't act too sluggish I would leave it as is.
As you have found out the memory doesn't need to be matched pairs on your PC
