Mark Allanson
posted on 5/12/06 at 10:37 PM |
Gat to english translator requiredes
Can anyone tell me what this means, and more to the point, what to do about it
Mark
Fatgadget
posted on 5/12/06 at 10:46 PM |
It means you have performed an illegal act.
Okay I will get me coat.....
caber
It means " Windows is screwed up again!"
What to do ? Buy a Mac
Caber
tegwin
What causes the error message to appear?
Mark Allanson
posted on 5/12/06 at 11:01 PM |
Its the first thing to appear when starting windoze, it started when I installed the ATI catalyst drives to enable twin display.
I have tried reinstalling them and even trying alternative ones but to no avail
MikeR
posted on 5/12/06 at 11:29 PM |
ok, .net is a programming support system. Microsoft provide a load of routines that developers use. Its set up a bit like a tree structure or the
enterance to an housing estate - bits lead to other bits.
The message is basically saying "the bit of the system that says where we can find .net is wrong, we've looked there and we can't
find the start of the housing estate. Correct it before we continue".
Best solution i'd guess is to try and repair the installation via the add / remove software. if that doesn't work, download .net from the
microsoft web site, remove it from your computer via add/remove and install it fresh.
Fatgadget
posted on 6/12/06 at 12:23 AM |
Have you tried performing a system restore by rolling back?
posted on 6/12/06 at 10:10 AM |
quote: Originally posted by Fatgadget
Have you tried performing a system restore by rolling back with a large hammer?
Mark Allanson
posted on 6/12/06 at 06:38 PM |
I'll try MikeR's suggestion first!!
posted on 11/12/06 at 06:57 PM |
The problem is that the ATI Catalyst control panel has been written using the .NET framework, and you do not have this installed on your machine.
Download and install the version 1.1 .NET framework from
Microsoft
