IainB
| posted on 15/1/07 at 09:33 PM |
Ram upgrade
Not for me but my folks back home. They have a Dell Dimension 4400: Pentium 4 2.0Ghz, 256Mb memory, etc.
Looking to upgrade to 512Mb but no idea what type of Ram I need. They cant seem to find the service tag so Dell website isnt much use. Anyone know
what motherboard and ram was being used back then?
Any help much appriciated!
Thanks,
Iain
http://s43.photobucket.com/albums/e365/IainB1986/
| posted on 15/1/07 at 09:38 PM |
Get a glimpse of the stick of ram in there and match it up. It may be better to throw that 256 away and put new 512 in.
Make sure they are not matched pairs though as well.
scottc
| posted on 15/1/07 at 09:39 PM |
You need DDR PC2700 with a maximum of 512MB per slot (only two slots though)
have a look here to confirm..... http://www.crucial.com/store/listparts.aspx?model=Dimension+4400+Series
Rek
| posted on 15/1/07 at 09:41 PM |
Crucial also have a system scanner that will tell you what slots are free and recommend a module type
MikeR
| posted on 15/1/07 at 09:46 PM |
if youre going to the hassle of upgrading the memory i'd slap in 2x512. It will make a great difference and future proof the machine for a few
years.
(but you'll also find 512mb a great improvement)
IainB
| posted on 15/1/07 at 09:58 PM |
Good stuff chaps! Im in the middle of ordering them a TFT from ebuyer.com so I may as well just get a single 512mb DDR PC2700 chip while im at it?
Cant really squeeze £££ out of them for a Gb chip but could always stick another 512mb in when the time comes (as il have a spare slot)
Many thanks gents,
Iain
COREdevelopments
| posted on 15/1/07 at 10:04 PM |
sorry to inturupt your thread but i to have a ram problem, bought a pc from tesco few months back, called iQon.
it says on the box 256mb ram
but when did a spec check with the aol broadband it only showing 192mb ram.
i dont know that much if anything at all about pc's, so is this acceptable?
also the pc is really slow starting the broadband!
any help would be really appreciated
thanks rob
RazMan
| posted on 15/1/07 at 10:28 PM |
Your on-board graphics is sharing your ram - quite common on the lower spec machines.
Raz
Humbug
| posted on 15/1/07 at 10:39 PM |
I can also recommend Crucial for price and speed of service
COREdevelopments
| posted on 15/1/07 at 10:45 PM |
thanks razman. what you sugest i do? shall i upgrade the ram? can you get ram upgrades for this make of pc?
RazMan
| posted on 15/1/07 at 10:56 PM |
As in the original post, it is probably best to whip out the old ram and see what spec it is, then either add to it or swap it for larger sims.
hth
Raz
COREdevelopments
| posted on 15/1/07 at 10:58 PM |
thanks again razman, goota get it done as it so slow it frustrating.
cheers
rob
jlparsons
| posted on 15/1/07 at 11:10 PM |
careful there, in the days they were selling 2 gig pentium 4s there was still SDRAM about, check exactly what you've got before you buy.
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during
shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to
approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable
parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television.
Keep cool; process promptly.
phoenix70
| posted on 15/1/07 at 11:16 PM |
Just hope it isn't RAMBUS ram, cause that stuff is very expensive (easy way to check that is all ram slots are full, the RAMBUS ram required
empty slots to be filled with a blank memory module)
