Author: Subject: Laptop problem
chrisg
posted on 21/1/07 at 08:42 PM Reply With Quote
Laptop problem
Hey Up
My laptop has gone tits up.
It'll only start in safe mode, it won't system restore, there's not much on it at the moment, is there some way of getting it sorted?
When turn it on normally it just runs the Windows XP splash screen forever
A rescue disc or something?
TIA
Chris
RichardK
posted on 21/1/07 at 09:02 PM Reply With Quote
Bloody 2nd time have wrote this, not logged in the first!
When in safe mode, go start, run, msconfig, start up tab then untick anything remotley dodgy especially browser toolbars.
Hope this helps
Rich
Gallery updated 11/01/2011
Agriv8
posted on 21/1/07 at 09:35 PM Reply With Quote
if that does not work boot with xp system disk and and select the repiar option.
might work.
may need the administrator password.
regards
agriv8
chrisg
posted on 21/1/07 at 09:43 PM Reply With Quote
Thanks for the reply Rich, I presume you mean that I should type "msconfig" in the run box? and click ok?
it just freezes at that point
And I haven't got a system disk
bugger
RichardK
posted on 21/1/07 at 09:52 PM Reply With Quote
Yes exactly, what you have done is correct. You say you haven't got a system disk, have look throught your disks and see if you've got a system restore cd or recovery cd, you should have got something with it or even just a windaz cd. I'm about an hour away if you are really stuck, u2u me if you need help and we'll sort something out.
Regards
Rich
[Edited on 21/1/07 by RichardK]
Avoneer
Did you have owt to loose?
Pat...
chrisg
posted on 21/1/07 at 09:57 PM Reply With Quote
fortunately not, I put everything on my pc on thursday!
Phew!
I'm going to go through all the cds and see if I can find anything.
I'll be in touch Rich!
posted on 21/1/07 at 10:22 PM Reply With Quote
Chris - what have you installed recently? Sounds like a anti-virus thing? Some manufacturer's are putting the total XP setup into a seperate partition - if you cold start into setup (DEL on startup) then boot from the XP partition it 'should' restore it all without loosing much/anything. If you have no new disc they are quite easy to come by if you know the right people - or go to car boot sales.
chrisg
posted on 21/1/07 at 10:32 PM Reply With Quote
Nothing really.
del on startup takes me to the "windows has failed to start" screen, with the choices of safe mode, safe with command promt, safe with networking, start windows normally and start from last known good configuration.
Is there anything "available" online
Chris
