cerbera
| posted on 11/2/07 at 07:05 PM |
Cant Format DVD+RW
Have got myself a new DVD drive (TSST corp CD/DVDW SH-S182D). When I put in a new DVD+RW and try and burn an image file in Alcohol it says I have an
unformatted disc. So I go to the Erase Wizard and try to perform a Full Mode Erase/Format I get the following "Error Message: [05/20/00] -
Invalid Command Operation Code".
Have tried doing the same in Nero but with no luck.
Have tried Googling for an answer to no avail. Any of you bright sparks on here got a solution.....please!
Ta.
RichardK
| posted on 11/2/07 at 08:03 PM |
I would try it first with a normal -R and see if it's anything to do with the format.
Regards
Rich
Gallery updated 11/01/2011
| posted on 11/2/07 at 09:30 PM |
I'd try a DVD-RW just to see if it's compatible. Both my drives don't like +R/RW...
Nothing to loose...
flak monkey
| posted on 11/2/07 at 09:32 PM |
Weirdly enough my drives that i have had, dislike DVD+R but are fine with DVD+RW, DVD-RW and DVD-R. Very strange.
As others have suggested, try a different disc format, as the drives can be fickle. If that doesnt work, take the drive back and complain
Sera
http://www.motosera.com
RazMan
| posted on 11/2/07 at 11:49 PM |
I tend to use all the DVD-xx and only have problems when trying to use DVD+xx. Frustrating isn't it
Raz
