Author: Subject: BT Hub, pile 'o' shyte!
donut
posted on 19/2/07 at 10:41 AM Reply With Quote
Does anyone else have a problem with their BT Home Hub? Mine keeps dropping out after an hour or so. I have to unplug the power for 30 secs and wait (half a lifetime) for it to boot again. I have checked the filters and all seems ok.
All BT suggest is to re boot it each time!! Think I'm gonna go back to a std router.
macnab
posted on 19/2/07 at 10:56 AM Reply With Quote
I got one and it's been just fine, get very hot though which scares me a bit, wouldn't leave it on overnight...
macnab
posted on 19/2/07 at 10:57 AM Reply With Quote
I have to unplug the power for 30 secs and wait (half a lifetime) for it to boot again. :
though with such a short lifespan your probably dead by now...
zxrlocost
posted on 19/2/07 at 11:12 AM Reply With Quote
I have one everything works ok apart from the phone what a pile of shite
massive delay when you answer before the other person can hear you
the loudest ring tone is equivalent to the quietest Ive ever heard.
it also doesnt ring sometimes for people who are calling
IS THIS MODERN TECHNOLOGY I ASK
why do we mess there was nothing wrong with any original cordless phone.
who type approves these things there paid about 100k a year to do this shite
do they all sit round the table and say FANTASTIC were moving forward guys doesnt anyone say hold on a minute the phones crap
Andy is my rant helping your decisions PS the internet side works fine sort of
also the amount of useless tosh its installed on my computer is absolutely ridiculous...
I shall not renew the contract next year as I also dont like speaking to Raja Raja for half an hour whos reading his manuscript of a computer and hasnt got a clue what Im on about
I dont care who they employe or what colour but it would help if we could understand each other!!!!
I am going to live in a tent no tv no phone no nothing just women and cars
macnab
posted on 19/2/07 at 11:28 AM Reply With Quote
Hmm those phones problems sound just like mine, thought it was our old phone line
Maybe not…
donut
posted on 19/2/07 at 12:20 PM Reply With Quote
Been using the internet for a couple of hours and it has bummed out on me 4 times now
Pezza
posted on 19/2/07 at 01:21 PM Reply With Quote
My bt service round here is just shite Andy, constantly have to reboot the router when the dsl goes down for a second.
It's not a bt hub either, this is a linksys one I bought to have wireless throughout the house.
Got an email the other day which took 6 hours to arrive from the time it was sent, and bearing in mind i'm meant to have a 2mb line, i'm regularly getting less than 512k speed
Wrote them a shitty email, but they prolly aint got it yet as I only sent it 3 hours ago lol
Pez
ps I don't think they've changed the phone lines down my road since the fooking twenties by the look of 'em.
[Edited on 19-2-07 by Pezza]
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
Mr G
posted on 19/2/07 at 02:04 PM Reply With Quote
Your telephone line attenuation / Noise margin can cause loads of problems with disconnections, especially in the evening when background noise increases.
If your noise margin goes below 6db then your usually in trouble. Roughly the higher this figure is the better.
With line attenuation the low the better, if you live a long way away from the exchange it will be high and vice versa.
Most routers will give you the info of your line, i'm not sure how to access this on the home hub. If you've got a mate with a standard router (linksys/netgear etc) then you could plug it in and view your line stats.
It's important that your telephone socket wiring is up to scratch. With NTE-5 master socket bt have been fiting for a few years you can unscrew and pull out the bottom half to reveal your test socket (carefull as it will have any extensions connected to the backside of the plate)
NTE5
You can now plug your router/modem directly into the test socket. The test socket is a full size normal telephone plug so you may need to dig out an old 56k modem lead or use an adapter so that a rj11 modem plug can be connected to it.
rj11 adapter
No adsl filter is required as your only connecting an adsl device to the line.
By plugging directly into the NTE-5 socket your creating the best connection possible to test to see if the extension wiring is degrading or interfering with your line quality.
While your at the NTE5 box it's wise to disconnect the orange and white bell wire. This was used years ago when we were on the pulse system and is not needed anymore and can have an effect causing interference when wired into extensions. The only wires required goto terminals 2 and 5 on the faceplate.
If it turns out to be your wiring then you can renew any extensions that you have.
Personally I fitted a new aftermarket NTE5 faceplate that has a seperate adsl socket on the front that I plug my modem/router directly into - it has very good inbuilt filters for seperating the adsl and normal voice signals
It lets you connect extensions that are already filtered so no more dangly filters hanging out of sockets.
After fitting the above it improved my line speed upto nearly its full potential of 8mb
AS long as your sure that the wiring your side of the master socket is up to scratch then you can further investigate the problem being with bt and your line to the exchange or their network/home hub etc etc.
EDIT:
Just found a site with someone posting the stats from their home hub so it should be there in one of the menu's - It will look like this:
Link Information
Uptime: 0 days, 0:28:48
Modulation: G.992.1 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,856
Data Transferred (Sent/Received) [KB/MB]: 656.00 / 9.04
Output Power (Up/Down) [dBm]: 11.5 / 16.0
Line Attenuation (Up/Down) [dB]: 31.5 / 56.0
SN Margin (Up/Down) [dB]: 17.0 / 15.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 105 / 0
FEC Errors (Up/Down): 0 / 52
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 0
HTH
G
[Edited on 19/2/07 by Mr G]
Dillinger1977
posted on 19/2/07 at 03:35 PM Reply With Quote
i got a free BT hub when i upgraded my line speed.
the router config was awful, it installed a ton of crap that i didnt want (no option to not install) and I barely got a signal with wireless from upstairs.
oh and yes it kept dropping connection.
replaced within the hour with my old belkin one, no troubles since.
Of course I cant use their 'free' BT talk thing but i'd rather keep my old tech that actually works.
what a waste of hardware, i feel guilty about not using it. brand new BT hub phone arrived too and its never been out the box. (looks quite nice though!)
-Rog
Pants On Fire
posted on 19/2/07 at 04:47 PM Reply With Quote
Installed it when it arrived, took it out 2 days later, the phone is junk and the wireless is next to useless, back to the Belkin.
Anyone want a 2 day old BT Home Hub?
[Edited on 19/2/07 by Pants On Fire]
Humbug
posted on 19/2/07 at 05:01 PM Reply With Quote
I changed from BT residential to BT Business (for work) and they supplied a new router/modem thingy... really crap, so I went back to the wireless Linksys one.
btw, the snapshot of someone else's stats above seems to confirm the "half life"... it says uptime was 28 mins!
donut
posted on 19/2/07 at 05:06 PM Reply With Quote
Next time it conks out i'll be doing the same!
nitram38
posted on 19/2/07 at 06:25 PM Reply With Quote
Donut, is it only a few days old?
If it is then you will get drop outs for a while (if all fails read your instructions ).
It will be trying to figure out the best connections for up to a month.
Mine did this for a few days and now I don't have any problems.
I also have 4 PC's that network to it without any probs
donut
posted on 19/2/07 at 06:55 PM Reply With Quote
It's been doing it for about 3-4 weeks now and it's getting worse.
nitram38
posted on 19/2/07 at 07:02 PM Reply With Quote
Get BT to fix it, you are paying them enough !!!!!!!!!!!!
I have found them good as my line did have a couple of faults that they sorted really quickly
donut
posted on 19/2/07 at 07:30 PM Reply With Quote
All i get told is to re boot the hub!. I'm gonna get a adsl router and have done with it!
