| posted on 28/2/07 at 11:48 PM |
Sky Router
Hi all - hope someone could help me out here - well my neighbour!
He has just installed SKY BB and telephone with TV - he has lost his wits about the system not communicating with the Router.
I went round to analyse the situation and basically ended up with the same loss of wits with it. His PC never came with a dongle so I took around mine
to test the connectivity. I use Netgear Router myself (which is exactly the same one as the SKY one!) so I configured the netgear settings to mine to
test internet - it worked. Altered to his Signal and although it showed a strong signal it would not converse and I could not ping the router
either!
He explained he MAY have reset the password on the router to one he cant remember. I need to reset the passwords etc on the router to be able to
configure to connect to the internet. It works on a LAN but not WLAN on his system.
Any help would be appreciated!
stevebubs
| posted on 28/2/07 at 11:55 PM |
standard sky router password is
username: sky
password: admin
Security settings for connection should be on a sticker on the underside of the router.
HTH
Stephen
UncleFista
| posted on 1/3/07 at 02:22 AM |
There should be a reset button on the back, just a hole to stick a pin in..
Tony Bond / UncleFista
| posted on 1/3/07 at 07:51 AM |
If you can't ping the router it is LAN problem, his router may be using a different IP address range.
