westf27
| posted on 8/3/07 at 08:46 PM |
lcd screen
got an e machine pc which i need to clean out for a friend.Thought i could get my lcd screen to work on it but it says no video signal.The only
difference between the two screens is one plugs into the mains and the other into the pc mains power supply.Would that be the reason it says no
signal.
555
RichardK
| posted on 8/3/07 at 08:51 PM |
nah, no differnece between the two, except the monitor will power off when the pc powers off.
Gallery updated 11/01/2011
RichardK
| posted on 8/3/07 at 08:53 PM |
Has it got two video cards in it, the one you have plugged the monitor into may the onboard one and maybe disabled in the bios.
Just a thought.
Rich
joneh
| posted on 8/3/07 at 08:57 PM |
You probably have the resolution / refresh rate set too high for the LCD. Lower the settings to 800X600 and work up.
bodger
| posted on 8/3/07 at 09:33 PM |
What sort of video connector is it?
stevebubs
| posted on 9/3/07 at 12:36 AM |
Boot into VGA mode...
bodger
| posted on 10/3/07 at 10:51 PM |
If it uses a DVI connector then maybe its cos the pc is outputting an analog signal but the monitor is expecting digital (or vice versa). Not all DVI
leads are the same.
