andrew-theasby
posted on 10/3/07 at 07:39 PM |
solidworks 2007 weldments question
Hi, just been playing with the tutorials on weldments, but is it possible to use the wire diagram as an outside measurement when placing the bars on
or do they always have to represent the centre line. For example i want to make a box section frame 500x500x500 but at the moment i can only do this
by drawing a sketch 25mm smaller and placing the box section on this. Im sure its really simple but i seem to be struggling a bit. Thanks
Chis_5984
posted on 10/3/07 at 10:01 PM |
Andrew,
You can locate the profile section WRT the wire diagram (line sketch) by altering the piece point. Click 'Locate Profile' at the bottom of
the structural member menu then just select a vertex or point created in the profile sketch.
Not sure if thats what your asking or if that helps..........
Chris
andrew-theasby
posted on 11/3/07 at 12:08 AM |
spot on thanks for that. Its a bit over the top i know, but im just designing a trolley for my welder as a practice. Cheers
