zxrlocost
posted on 15/3/07 at 02:59 PM |
export as a JPEG
hi why when I export as a JPEG and open the file again its blocky?
ie it includes text and pics the text goes more blocky
thanks chris
I think ive tried setting the pixels and it makes no difference
dan__wright
posted on 15/3/07 at 03:03 PM |
it will be the export settings, need to check the quality setting
zxrlocost
posted on 15/3/07 at 03:06 PM |
when you preview it in windows it looks fine
when you open it in adobe or export to web its blocky
whether 2.4mb or 160kb
posted on 15/3/07 at 03:12 PM |
what software are you using?
zxrlocost
posted on 15/3/07 at 03:28 PM |
corel draw and photoshop
RazMan
posted on 15/3/07 at 05:05 PM |
Corel Draw has all sorts of options when you export, including resolution - set this to around 300dpi and then choose the size to want the finished
pic to end up (for an avatar use ~200)
Hope that helps
Raz
posted on 15/3/07 at 05:10 PM |
What format were they?
Before you exported them as .jpg files. As said, check what you are saving them at as the optimiser is probably set low and .jpg are known as a lossy
format and only saves what the program deems necessary to interpret the picture. If it was already a jpeg use save as or save original.
[Edited on 15/3/07 by Peteff]
