Wadders
posted on 13/4/07 at 07:57 PM |
External hard drive vanished
eek! bought a Toshiba external hard drive about 18 months ago to store my photos and sage backups, and i think its died It lights up as normal, but
the drive letter has gone from my computer, also i think it used to get quite warm, but its clap cold now, have tried a couple of different usb cables
with no joy.
Don't care if the drive is shagged, but the data on it is priceless ( to me anyhow ) Where would be the best place to get the data recovered,
and will i need a second mortgage?
TIA
Al.
RichardK
| posted on 13/4/07 at 08:11 PM |
Data recovery is very expensive,they know they have you by the short and curlies if your data is that valuable.
Onto a more postive note quite ofter inside the external caddy is a normal laptop hard drive which can then be put inbto another caddy and the data
recovered.
If you would like me to take a look at it while we have a chat don't mind. The offers is there.
BTW my proper job is being a pc tech.
Let me know.
Rich
Gallery updated 11/01/2011
Wadders
| posted on 13/4/07 at 08:47 PM |
Hi Rich
you have u2u
Al.
recovered.
Let me know.
Rich
| posted on 14/4/07 at 09:01 AM |
Could be a power supply problem --- it is an external power supply check it with a volt meter quite often plug in power adaptors fail because the
cord has been wounfd round the plug.
If it power is supplied via the USB try the drive on a different PC.
If this dosen't work open up the external case and check the connectors are fully home, I have seen at one external drive where the 80 pin
connector had come partly unplugged.
If that dosen't work remove the HD and try it in connected directly to a PC motherboard IDE socket.
Keith Weiland
| posted on 14/4/07 at 05:22 PM |
What Britishtrident said, An external HD is basically an internal drive in a caddy so if the caddy is at fault you can put the drive in your computer
and it should work ok.
