Author: Subject: PC running Vista
westf27
posted on 4/7/07 at 03:53 PM Reply With Quote
PC running Vista
Bought new pc tower preloaded with vista buts its slow and despite 512mb ram which i am told is not enough i am fed up with it.I assume vista is on a partition on the hard drive and can get restored or duplicated as necessary.Thinking i'll copy xp onto my drive which should run ok with the ram.Bit of a dummy so how best to do it or am i wasting my time/cant be done.I have xp restore disks from a previous pc of the same make and also a full copy of xp professional.Any help appreciated
RazMan
posted on 4/7/07 at 04:11 PM Reply With Quote
Keep Vista and just stick 1Gb (ideally 2Gb) of ram in there - you won't regret it
Raz
mookaloid
posted on 4/7/07 at 04:38 PM Reply With Quote
As above
McLannahan
posted on 4/7/07 at 04:48 PM Reply With Quote
Have 2 Gig in my PC's running Vista and it's quite good. Price of RAM is so reasonable at the moment. £30 or less will see you upgrading the laptop to something decent!
posted on 4/7/07 at 05:25 PM Reply With Quote
Even with Xp Pro 1gb is the norm these days, 2 to 4 for Vista.
Turn down the special effects.
Also if you have Norton installed ditch it for something less resource hogging such as Free Anti-Vir , and check what MS rubbish is running (ie indexing).
Down load HijackThis run it -- it is good for showing unwanted stuff on a new Pc.
pre-installed
Loading Skype a start up can also put a drag on performance.
martyn_16v
posted on 4/7/07 at 05:27 PM Reply With Quote
Change the theme to windows classic, it'll make it all look like w2000(ish) but it does make a big difference.
westf27
posted on 4/7/07 at 05:44 PM Reply With Quote
thanks ya all
