Ivan
posted on 23/7/07 at 08:50 AM |
Control Panel Problem
I am having a minor problem with Win XP Pro.
When you open Control panel/ Add or Remove Programs it populates the form with about 5 of the programs then leaves a huge gap and populates the rest
of the programs at the bottom of the form.
How do I get rid of the gap?
Image deleted by owner
iscmatt
posted on 23/7/07 at 01:13 PM |
not much help but i have had this problem on my laptop windows xp for about a year now!
would be nice to know how to get rid of it and why it is caused!
posted on 23/7/07 at 04:13 PM |
Re-install XP looks like a glitch... shouldn't erase anything but will correct this error.
Tigger
posted on 23/7/07 at 04:50 PM |
Ivan,
Do you have anywhere an installed program that is idented in the list on Add/Remove programs?
Apparently, this is due to an un-installed program not registering properly in the registry. It should have a -1 against it in the registry instead of
a 1.
See THIS LINK http://forums.tweakguides.com/showthread.php?t=2024
It mentions Autocad but would be specific to whatever program you have uninstalled.
Hope that helps
Tigger
[Edited on 23/7/07 by Tigger]
Ivan
posted on 23/7/07 at 05:34 PM |
Thanks Tigger and Steve - I will follow up on Tigger's suggestion first and will lay off Steves as I am currently busy with a time critical
consultancy job and don't want to risk messing with the opperating system until the job is over - and yes autocad was recently installed.
Tigger
posted on 25/7/07 at 09:24 PM |
Let us know if it works Ivan,
Could help others in the same sticky situation
Tigger
Ivan
posted on 26/7/07 at 06:54 AM |
Will do.
