Benzine
| posted on 3/8/07 at 07:03 PM |
Watercooling pump
I've just finished my new watercooling pc. It uses a pond pump and a mini radiator (the car, not the size). I was going for the locost approach
What ways are there of making a pump quieter? At the moment it's outside my case, most of the noise it makes comes from vibrating the desk
it's on. Rubber/foam/sound insulation?
[Edited on 3/8/07 by Benzine]
bimbleuk
| posted on 3/8/07 at 07:17 PM |
Hmm do I want to admit to owning a water cooled PC on a public forum ...... Oh well I'd try rubber or even better gel pads from saddles, mouse
mats n wrist rests. Mines just a badged aquarium pump on rubber feet. If that's not robust enough then silicon filled engine mounts, from the
scrappy off course.
[Edited on 3/8/07 by bimbleuk]
RazMan
| posted on 3/8/07 at 10:45 PM |
Speed controller?
Raz
Benzine
| posted on 4/8/07 at 06:51 AM |
quote: Originally posted by RazMan
Speed controller?
I had thought about that... how would I go about it? At the moment it's a mains cord straight into the pump. I wouldn't know where to
start.
RazMan
| posted on 4/8/07 at 07:53 AM |
Ah ... an AC pump might be tricky. You might be better off changing to a variable speed pump in that case
Raz
Benzine
| posted on 4/8/07 at 11:50 AM |
Tricky means it's possible though doesn't it Couldn't i wire it up to a dimmer switch or something?
RazMan
| posted on 4/8/07 at 12:30 PM |
Didn't think of that! Certainly worth a go
Raz
Benzine
| posted on 4/9/07 at 09:29 PM |
RE: wiring up a dimmer switch.
The pump being AC, will it draw more amps if you give it less volts and the motor will burn out?
40inches
| posted on 5/9/07 at 07:39 PM |
Put mine inside case mounted on rubber feet, switches on through a 12volt relay(240v ac through contacts) been running for about a year with no
probs
