New Topic New Reply
Author: Subject: Handbrake Cable Routing
matt.c
posted on 9/9/07 at 09:01 AM Reply With Quote
Started fitting the handbrake cables yesterday and was told by a friend that i have to grind some of the diff away to get some clearence for the cables to run. See pic..
Hand Brake routing
Hand Brake routing
Is there another way to do it before i start grinding?
indykid
posted on 9/9/07 at 02:04 PM Reply With Quote
nope. start grinding
hth
tom
indykid
posted on 9/9/07 at 02:09 PM Reply With Quote
just noticed your cables seem to run under the 50x25mm rhs member.
mine run through it in tubes, so i suppose you might have to remove even more material then i did.
Pezza
posted on 9/9/07 at 07:49 PM Reply With Quote
Mine's got the holes through the crossmember too for the cables to pass through.
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
matt.c
posted on 9/9/07 at 07:52 PM Reply With Quote
Yes mine has holes below but the cables are tight to the diff.
Looks like i will have to take the diff out again and start grinding!!
Catpuss
posted on 10/9/07 at 07:49 AM Reply With Quote
Mine go through the holes fine, then go over the diff. Using a couple of P clips to guide them. I bend the P Clips so they have a 45 degree twist in them. This allows the cables to have a guide with not too much stress. They then guide down the the front of the wheels via another P clip on the edges of the frame. Seems to work OK. The cable operates fine with a nice 5 clicks to full on.
matt.c
posted on 10/9/07 at 06:00 PM Reply With Quote
Have you got any pics of yours please?
Catpuss
posted on 11/9/07 at 07:24 PM Reply With Quote
I've put some in my photo archive under Handbrake Cable folder
New Topic New Reply
