Humbug
| posted on 17/9/07 at 06:28 AM |
HELP! PC won't boot up
...obviously not the one I'm typing this on . I went to start up my desktop PC this morning and it hangs on "Initializing USB
Controllers". Pressing F1 (for Setup) or Esc (for BBS menu???) don't work (could reboot again and press it earlier, maybe).
Any ideas, peeps?
[Edited on 17.09.2007 by Humbug].jpg)
bimbleuk
| posted on 17/9/07 at 07:29 AM |
First thing are there any USB devices plugged in, if so remove them (also floppies or CDs/DVDs.
Unplug it from the wall, give it 10 mins try again.
If that didn't work I would be taking the side off next to reset the BIOS using the motherboard jump (CMOS clear) or similar. Again unplug the
power lead when doing this to make sure it clears properly.
You may have some issues with BIOS settings immediately after though. hopefully your familiar with that part.
[Edited on 17/9/07 by bimbleuk]
| posted on 17/9/07 at 08:11 AM |
Boot Sequence.
Press for the BBS menu and set it to boot from the hard drive first, cd second and any other devices last.
richijenkin
| posted on 17/9/07 at 08:39 AM |
Does it beep at all?
Sounds like its not recognising the hard drive, check inside and make sure all cables are plugged in.
Humbug
| posted on 17/9/07 at 10:31 AM |
It doesn't give me time to press any of the buttons.
I don't think it beeps, so I will check the hard disk connections
Ta
Humbug
| posted on 17/9/07 at 11:51 AM |
SOLVED - thanks once again to Locostbuilders.
I opend up the PC, checked the SATA cable on the hard disc - seemed ok, but I removed it and replugged it. No joy. Then I plugged it into once of the
other disk drive slots on the motherboard and bingo!
Thanks again
| posted on 17/9/07 at 12:35 PM |
Thanks again
To me that sounds like a warning - BACK UP al your sensative information before it goes pop!
Humbug
| posted on 17/9/07 at 12:53 PM |
Thanks again
I never said I hadn't backed up my data! I do incremental backups of key things every day, so I was able to get my email etc. on
another machine.
