Mark Allanson
| posted on 22/9/07 at 05:07 PM |
Which one?
I am just about to do the upgrade on my computer, from 1800 athlon with 133fsb to 4200 dual core with 500?fsb.
When I bought the processor, I didn't realise that the cooler came with it so I bought one specially.
Shall I use the tried and tested AMD cooler or the much bigger 'Samurai' one?
| posted on 22/9/07 at 05:51 PM |
The bigger one loos like it's a liqud cooled jobbie - do you need to plumb it in?
Either way I'd use the Samurai one as it has a cool name
cloudy
| posted on 22/9/07 at 05:52 PM |
use the quieter of the two, the stock heatsink does a great job...
ecosse
| posted on 22/9/07 at 06:32 PM |
Stock heatsink will do a good job, Samurai is for the clockers really
Alex
UncleFista
| posted on 22/9/07 at 08:07 PM |
If it was me, I'd run the bigger one at 7volts, for good cooling with less noise.
Just use the 12v line as positive and the 5v line as the negative. I do this with all my case fans
The "pipes" in the bigger cooler are "heat pipes" there's a liquid/gas inside that evaporates and condenses transferring
heat to the fins.
[Edited on 22/9/07 by UncleFista]
Tony Bond / UncleFista
bimbleuk
| posted on 23/9/07 at 06:00 AM |
As above ^^^^
Go for the biggest fan you can fit and run it slowly to reduce noise. The stock coolers are good at stock speeds and even a little higher but they
build them to a cost so the fans are usually small and noisy. Your case cooling with have a big effect though.
RazMan
| posted on 23/9/07 at 07:19 AM |
Check the AMD fan to see if it has an on-board heat sensor/speed control. If both connectors are identical, the heatpipe cooler will probably be
quieter anyway as it has a larger fan, especially if it is heat controlled by the motherboard.
[Edited on 23-9-07 by RazMan]
Raz
Mark Allanson
| posted on 23/9/07 at 04:33 PM |
I used the AMD one in the end as the size of the samurai was a bit of a problem.
One big problem I encountered was the MB has a power connector with 24 pins and my power supply has a 20 pin, bugger!
Ebuyer have converters for only £2 so not a disaster, but it does mean I cannot fire up the computer until Tuesday night - and there was me getting
all excited
